TS-459 Pro+ with two NICs
Discussion on setting up QNAP NAS products.
nathans77
Post by nathans77 »
The TS-459 Pro+ has two NICs. I would like to know if it is possible to increase the input for backups by connecting the second NIC. And if so, how that can be done. Thanks
pwilson
Re: TS-459 Pro+ with two NICs
Post by pwilson »
nathans77 wrote:The TS-459 Pro+ has two NICs. I would like to know if it is possible to increase the input for backups by connecting the second NIC. And if so, how that can be done. Thanks
Port Trunking doesn't help in this circumstance. The useful Port Trunking options on the NAS require an expensive "Managed" Gigabit Switch, and this won't do anything for your throughput unless there are multiple Dual-NIC devices accessing it at the same time.
Check out the Port Trunking information in the fine manual.
Patrick M. Wilson
Victoria, BC Canada
nathans77
Post by nathans77 »
Ok, thanks. Was curious if that'd help. :)
kherr4377
Been there, done that
Post by kherr4377 »
I did my main 469L(Q1) with LACP and have had good results. While backing up to two other NAS's (A second 469L(Q2) and a NetReady Ultra2+) and get ~190MB throughput between the two boxes. The Ultra was on the same switch as the Q1 and the Q2 was 2 switches (regular switches) downstream. Only the Q1 had LACP enabled, and of course a managed switch to support it. It will never exceed the speed of a regular connect to any one transfer. You need multiple connections to realize any speed increase.
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
pwilson
Post by pwilson »
kherr4377 wrote:I did my main 469L(Q1) with LACP and have had good results. While backing up to two other NAS's (A second 469L(Q2) and a NetReady Ultra2+) and get ~190MB throughput between the two boxes. The Ultra was on the same switch as the Q1 and the Q2 was 2 switches (regular switches) downstream. Only the Q1 had LACP enabled, and of course a managed switch to support it. It will never exceed the speed of a regular connect to any one transfer. You need multiple connections to realize any speed increase.
With numbers like that I'd say your configuration was definitely successful. Great work!
Patrick M. Wilson
Victoria, BC Canada
kherr4377
Post by kherr4377 »
It's more of a "can I do" as apposed to " I need to do" thing......
Production :
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Return to “Turbo Station Installation & Setup”
