hello everyone.
considered my needs to use the nas the choice is addressed to these two models TVS-463 and TVS-471.
my doubt is the AMD model TVS-X63, since I have always opted for intel processors.
someone, kindly, could tell me their experience with this AMD processor, you think it's worth venturing?
I would not make a charge and then repent.
thank you.
help purchase choice.
- toledo
QNAP TVS-471 I3-4GB ~ 3 dischi 2T Western Digital RED EFRX ~ Firmware 4.1
Router Drytek modello Vigor 2830 n
- Toxic17
Re: help purchase choice.
Price wise here in the UK the AMD is approx 300 UKP cheaper than the 471 (i3) as pricing is shown today on some UK sites. Apart from Processors i would say the feature set is very similar. I dont think both the x71 or the x63 are actually in stock until mid Feb by the earliest.
http://www.qnap.com/i/in/product/contra ... %5B%5D=172
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
- toledo
hello.
I see the signature that uses the TVS-463 are you satisfied?
in Italy is expected to arrive in the warehouse of my seller this week.
the price without VAT (tax) for the model TVS-€ 463,539 instead for TVS-471 I3 € 760.37
- Toxic17
i dont have one as yet, my signature says what hardware have.
They are not available so cannot comment on the x63 model.
Regards Simon
Qnap Downloads
Qnap Downloads
toledo wrote:considered my needs
What are your needs? AMD's processors are nice but simply not as strong as Intel's. However, I believe people purchase way more processor than they actually need. Maybe you should try out the model before upgrading! I know I should have.
Hello.
I have got the same dilemma. I would like to be able to run 1 Windows VM and 2 or 3 Linux VMs at the same time (with TVS-663 or TVS-671 and 16GB RAM).
What is the exact AMD processor which is build in TVS-X63 ?
Best Regards
Chris
Best Regards
Chris
- QNAPJason
- QNAP Staff
The TVS-x63 performance and MSRP are between TVS-x71 & TS-x53 Pro.
They all can run multiple VMs.
The AMD processor on TVS-x63 is the top of the line SKU from the G-series APU family.
It is quad-core 2.4GHz with only 25W TDP and supports hardware encryption, transcoding, and AMD-V for virtualization, with an additional PCIe slot for network expansion.
The TVS-x63 can also support max 2 UX-800P for storage expansion if you run out of storage in the future.
If you have the budget, then going with TVS-x71 is also good because it will be a more powerful NAS with various CPU options. If you need hardware encryption, then you must go with the i3 and above. The overall software features are almost identical.
- toledo
thanks jason,
you have been very kind and comprehensive response.
Is the TVS-463 better then the TS-453 Pro ? In all functions?
- QNAPJason
- QNAP Staff
Hi mkbr1,
Yes, TVS-463 is better than TS-453 Pro in these aspects:
quad-core 2.4 GHz APU design
PCIe slot for optional quad LAN or 10GbE ports
hardware-based encryption acceleration
Dual HDMI 1080P mirrored output
Radeon graphics
Upscale exterior metal finish
Radeon graphics
