QG-103N(QGenie) Upgrade HD?
Can the hard drive be replaced or are you stuck with the 32GB SSD it comes with? Would be nice to put a 256GB HD in it.
- schumaku
Re: QG-103N(QGenie) Upgrade HD?
Wild guess - it's most likely something soldered-on, like an eMMC chip for example. Small and energy effective.father_mande wrote:Officially response is NO you can't change it
It's only clipped together, so with right tool you can open.
Internal Storage is a simple USB 3.0 stick with 32GB.
You can swap this one to a 256GB (formated with NTFS)
And simply copy all stuff from original 32GB storage to new one.
At me, works seamless.
(Keep in mind, waranty will void)
- schumaku
Afraid, it's it not ... a standard USB 3.0 does provide 5 V DC plus/minus some, for low (150 mA) and high power (up to 900 mA) ... while the internal one here is just supplying 3.3 V DC, and the power available has limitations of course, too. Luck and fail can be very near.hartmann wrote:Internal Storage is a simple USB 3.0 stick with 32GB.
