Download Station v2 Configuration
I recently upgraded to F/W 3.4.0 Build 0212T and started using Download Station v2 for torrents. I have a couple of questions regarding the target folder for downloads:
1) When configuring the "Default directory for downloaded files", I can only choose top-level directories from a drop-down list. I would like to choose a sub-directory for this.
2) Even though my default directory for downloaded files is currently set to "Public", and the folder permissions are set to read-write (even for Guest access), downloaded folders are created with 755 permissions. I would like to set this to 777.
Given that the "Settings" page does not make these settings possible, is there a configuration file I can edit manually to achieve the settings I'm looking for?
Thanks.
Thanks.
Re: Download Station v2 Configuration
I solved the top-level directory problem by adding the folder to the list manually - ssh in and:
Now go down to the ShowSetting line and insert a line so the code looks like this:
Replacing Public/Share/Download with an existing directory on a share (Public is the name of the share in this example).
Now hit escape, :wq and you're done. All at your own risk but it seems to work fine for me.
I'm struggling with the permissions problem as well.
cd /mnt/ext/home/httpd/cgi-bin/Qdownload/lib/
vi ds_action.js
/sharelist_ds.reload
i
DS.CFG_sharelist_ds.reload({
callback: function(records){
for(var i=0; i< records.length; i++){
DS.CFG_sharelist_Ary[i] = DS.CFG_sharelist_ds.getAt(i).get('Name');
DS.CFG_sharelist_Ary[i] = 'Public/Torrent/Download';
ShowSetting();
Thanks for the tip for adding sub-folders to the list!
As for the permissions on files and directories, I'm able to get the behaviour I want manually by executing the following commands:
umask 0000
/etc/init.d/btd.sh restart
Folders are then created as drwxrwxrwx (0777), and files as -rw-rw-rw- (0666).
I would like to make this permanent across reboots, but I'm finding out that many configuration files are overwritten at startup. It looks like I may need to create an autorun.sh script as described in http://wiki.qnap.com/wiki/Running_Your_ ... at_Startup
I'm not clear on where in the startup sequence autorun.sh would be run, in comparison to files in /etc/rcS.d for example.
umask 0000
Where are the configuration files located on the QNAP TS-509?
I just updated the firmware to 3.4 and looking at the settings on the Download Station, all I see are all top level directories.
Looks like /home/httpd/cgi-bin/Qdownload/lib
The specified code will only work for one directory addition. If you try to add multiple directories only last one added wins. To add multiple directories to the list use the following instead:
Replace <directory-#> with the directory you want to see listed. You can add as many as you wish, they will appear at the bottom of the selection list in the order you entered them in. Just be sure they are all added before the ShowSetting(); line.
Thanks for finding this!
DS.CFG_sharelist_Ary[i++] = '<directory-1>';
DS.CFG_sharelist_Ary[i++] = '<directory-2>';
DS.CFG_sharelist_Ary[i++] = '<directory-n>';
ShowSetting();
I'm running firmware 3.8.2 and things have changed a little bit.
The code is now in ds_tool.js
Search for these lines:
and add this line of code (you can add it multiple times for more share names)
Thanks to ashre and covvie for giving me the right directions!
for(var g=0;g<jo.shareName.length;g++){
DS.CFG_sharelist_Ary[g] = [jo.shareName[g],jo.shareName[g]];
DS.CFG_sharefolder_Ary[g++] = ['directory/subdirectory','directory/subdirectory'];
Hi CasperBE,
I tried to change the code you mentioed but nothing really happened. I am wondering if I have to restart something other then reload the page.
I also tried to change the code in a different way like this:
Also interested in if there is any way to debug what I made?
Could you please help me with advice?
Thanks in advance!
success: function(o){
var jo =Ext.util.JSON.decode(o.responseText);
if(jo.result==DS.status.jsonSuccess){
// for(var g=0;g<jo.shareName.length;g++){
// DS.CFG_sharelist_Ary[g] = [jo.shareName[g],jo.shareName[g]];
DS.CFG_sharelist_Ary[0] = ['Download/Vera','Download/Vera'];
DS.CFG_sharelist_Ary[1] = ['Download','Download'];
DS.CFG_sharelist_Ary[2] = ['Media','Media'];
DS.CFG_sharelist_Ary[3] = ['home','home'];
DS.dym.defDLFolder = jo.mvFolder;
Thanks in advance!
Hi dulo,
I don't know if you still need it, but this way works for me on a Qnap TS-269pro with firmware 4.1.0:
In /home/httpd/cgi-bin/Qdownload/libs/ds-setup.js add another data.push():
In your case the following should work:
Kind regards,
Christian
DS.RPC.Misc.getFolderList(function (err, o) {
var data = [];
for (var i = 0, len = o.shareName.length ; i < len ; ++i) {
data.push([o.shareName[i]]);
data.push(["directory/subdirectory"]);
shareStore.loadData(data);
var data = [];
// for (var i = 0, len = o.shareName.length ; i < len ; ++i) {
// data.push([o.shareName[i]]);
data.push(["Download/Vera"]);
data.push(["Download"]);
data.push(["Media"]);
data.push(["home"]);
Christian
Hi Christian!
I made Download/torrentz directory from admin account, all permissions are correct. I edited my /home/httpd/cgi-bin/Qdownload/libs/ds-setup.js like that :
But. After i save the file ( i double checked, all my changes was still there after closing the file), and reboot the NAS, nothing is changed. File is going back to default, and all settings are still the same. Without Download/torrentz section.
What am I doing wrong? Please help me mate
Regards!
var data = [];
data.push(["Download/torrentz"]);
Regards!
Or maybe there is another way to solve this problem?
I would like to switch Download directory from global (Download,Multimedia,WEb.etc...) to subdirectory like Download/somethinghere.
QNAP TS-212, Download Station 4.0.5
Thanks!
Thanks!
I'm sorry I can't remember doing anything special besides the stuff I described in my post. However, a reboot might not be necessary, disabling and re-enabling the Download Station in App Center might be enough.
If it doesn't work, you could ask sbrez81 http://forum.qnap.com/viewtopic.php?f=1 ... 14#p456467. He recently had the same problem. Maybe he remembers what he did...
