Hi, I'm trying to setup the Download Station (latest version 4.0.3) for unlimited seeding, how should I do ?
Thx.
Unlimited seeding
Unlimited seeding
QNAP TS-469L - QTS 4.2.0 (Build 20151118) - 1GB RAM - Serial Number Q133I10415
4x4TB Western Digital WD40EFRX RED - RAID 5
APC Back-UPS ES 700G
iMac 21,5 Late 2009 - 12GB RAM - OSX Mavericks 10.9.5
Re: Unlimited seeding
Hi, anyone that could help ? It's strange to me to don't have any chance to overcome this "restriction".
Thx, Roberto.
Thx, Roberto.
- Easy as a breeze
Although I use Download Station as my primary BT Client I have never messed with the seed ratios - however after reading your post I had a look - I see that you can change the ratio in % and have a range from 30 mins to 2 weeks & manual stop is this what you are referring too ?
1x TS-412 3x WD2003YYS (Enterprise) 1x WD20EFRX (Green) [Raid 0]
1x TS-412 3x WDC ED30EFRX (Red) 1X ST3000VN007 (IronWolf) [Raid 5]
1x TS-412 2x WD20EZRX (GREEN) & 2x WD20EARS (Green) [Raid 5]
1x TS-859pro 4x WD30EFRX (RED) & 4X ST3000VN007 (IronWolf) [Raid 5]
1x TS-869pro 8X HGST HDS724040ALE640 - (DeskTop) [Raid 5]
1x WDSharespace 4xWDC WD2003YYS (Enterprise) [Raid 0] - The worst NAS I have ever owned.
5x WD MybookWorld White light Edition (Which are fitted with WD Green drives as standard) also rubbish
Hi, I've updated Download Station to latest release yesterday: 4.0.5, in the ChangeLog I see: Remove download/upload rate limitation [NEW FEATURE]
I was thinking that as a way to finally have the "unlimited seeding until I manually stop it" but it seems to don't work, in my settings I've:
- Share Ratio: 999%
- Share Time: Manual Stop
but it stops when the Share Ratio achieve its defined value: 999%.
Is there a way (also modifying some configuration files over the NAS, I'm able to ssh into it and have good knwoledge about unix commands) to have "unlimited seeding time" ?
Thank you very much.
- Share Ratio: 999%
I'll try with 0 value in Share Ratio to see what will happen, thx for the suggestion.
I'm not a Download Station user at the moment but I would not interpret "Remove download/upload rate limitation" to have anything to do with the "Share Ratio". I would rather think that Qnap finally removed the limitation of the download rate being limited to 10*upload rate, that was so hated among leechers.dalrmi wrote:Hi, I've updated Download Station to latest release yesterday: 4.0.5, in the ChangeLog I see: Remove download/upload rate limitation [NEW FEATURE]
