Dumb Question - What Is Streaming?
Sorry for the dumb question - but I don't really understand what streaming is.
I've got a NAS and I've got a bunch of ripped DVDs stored on it. When I want to watch a film I open "Finder", navigate to the relevant DVD file on the NAS (ISO image, VOB, DVDMedia) and open it with either VLC or the Mac's DVD player. Is this classed as streaming or would there be some advantage if I used the NAS's Multimedia Station?
Sorry to be thick.
Sorry to be thick.
- Been there, done that
Re: Dumb Question - What Is Streaming?
I use Twonkey to 'stream' my ripped DVD/BD to my TVs. Computers are for computing, TVs are for movies ....
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Understood - if you've got a TV, but I haven't - which is why I watch DVDs on my computer. Does that mean that the NAS's Multimedia Station is only used for streaming to TVs
It depends. It would be streaming if the video playback started before the whole file is downloaded. It's however not easy to check (perhaps with a big video..).anotherusername wrote:I've got a NAS and I've got a bunch of ripped DVDs stored on it. When I want to watch a film I open "Finder", navigate to the relevant DVD file on the NAS (ISO image, VOB, DVDMedia) and open it with either VLC or the Mac's DVD player. Is this classed as streaming or would there be some advantage if I used the NAS's Multimedia Station?
The thing is: if you use some file-sharing protocol like AFP, NFS or SMB and double-click on a file two things can happen:
(1) the file manager actually downloads the file and passes the local (cached) copy to the program you want to open it with (e.g. "vlc /tmp/cached_copy.mpg")
(2) the file manager tells vlc to open the file directly from the server (e.g. "vlc smb://qnap/path/to/video.mpg").
Whether (1) or (2) happens depends on so many things that no answer can be given.
On the other hand, if you use an explicit streaming protocol (like DLNA), then you're streaming. (but streaming usually involves buffering, which means there's anyway no clear-cut technical difference between streaming and copying).
So no, you're neither being thick nor the question is dumb. There's just no clear answer..
Thanks Reinob.
I might have a look at the Media Centre.
- pwilson
Have you considered installing XBMC on your PC and/or Mac? It can open ISO's directly via SMB from both OS choices. (I have XBMC on all my Linux, Android, and Windows devices here).anotherusername wrote:Sorry for the dumb question - but I don't really understand what streaming is.
Sorry to be thick.
Patrick M. Wilson
Victoria, BC Canada
Hi Patrick. Thanks for the info. I had a quick look at XMBC and it doesn't seem to do anything for me that VLC doesn't.
- pwilson
It does a lot more than VLC here. Anyway, it's your environment, so the choice is yours to make.anotherusername wrote:Hi Patrick. Thanks for the info. I had a quick look at XMBC and it doesn't seem to do anything for me that VLC doesn't.
Patrick M. Wilson
Victoria, BC Canada
Patrick - I'm not being awkward - I simply don't understand and would appreciate some help. I find this field very, very confusing and I'm struggling to find any useful help on the web.
I play movies on my Mac using VLC or the Mac's DVD player. The movies are stored as DVDMedia, ISO, VOB and a few MP4s. What might XMBC give me that VLC doesn't?
- schumaku
Most applications use strong terms in my opinion.
Streaming is open a data stream from a server to a client, and immediate start playback. Some transport protocols are dedicated to streaming, others can be used for data transfer / upload / download but also for "endless" streaming.
Alternate approach is download a complete file, and start playback when the process has completed.
VLC will just play the one video you tell it to play.anotherusername wrote:I play movies on my Mac using VLC or the Mac's DVD player. The movies are stored as DVDMedia, ISO, VOB and a few MP4s. What might XMBC give me that VLC doesn't?
With XBMC you get a whole front-end where you can browse and play your stuff. So it sorta replaces the need for both a file explorer (or whatever you call it on the Mac, finder I think) and a video player. Let's say it's a more "integrated experience".
