I have a TS-419P - It works fine - the power schedule works fine, but I cannot wake it up with WOL?
In the manual it says that I have to go into EuP, but this tab and the WOL tab is not available in the system settings? Running version 4.1.1..
Any ideas how to fix this? (running Danish language if this makes a difference?)
QNAP TS-419P Wake on Lan
- pwilson
Re: QNAP TS-419P Wake on Lan
For WOL to work. You need "EuP disabled", and "WOL enabled".gordon38 wrote:Hi,
This functionality is broken on some Firmware Builds, but you have neglected to provide this information. Upgrade to QTS 4.1.2 Build 20150126.
Patrick M. Wilson
Victoria, BC Canada
Thank you.. Now updated to QTS 4.1.2..
However, the 2 tabs with EuP + WOL is still not available..
Any suggestions?
Any suggestions?
- pwilson
Submit a ticket with the QNAP Helpdesk. Both should be present.gordon38 wrote:Thank you.. Now updated to QTS 4.1.2..
Any suggestions?
Have you tried completely powering off the NAS, and then restarting it?
What does your "Power" screen look like? (Please review Forum FAQ: Can I post images?).
Patrick M. Wilson
Victoria, BC Canada
Will ubmit a ticket!
My power menu only holds 2 tabs (power recovery & power schedule)
- pwilson
Yes that definitely looks strange. Submit a ticket with the QNAP Helpdesk for further assistance.gordon38 wrote:Will ubmit a ticket!
Patrick M. Wilson
Victoria, BC Canada
If I remember correctly the TS-419P lacks hardware support for Wake-on-Lan. I think that it was added on the next model, the TS-419P+.
- pwilson
To be honest I vaguely recall the same thing. I owned a TS-419P+, and it definitely supported WOL. Unfortunately QNAP's "new" Website doesn't allow us to look at the technical specifications of older NAS models anymore, so I was unable to access the technical specifications for this TS-419P model. (It's a shame, as the "old" website provided this information in a very effective way).P3R wrote:If I remember correctly the TS-419P lacks hardware support for Wake-on-Lan. I think that it was added on the next model, the TS-419P+.
Rather that providing information I was unable to "confirm" on QNAP's website, I felt it was better to simply direct him to the Helpdesk so he could confirm this with QNAP directly. It is re-assuring though, that your recollection is the same as mine per: No WOL hardware provided.
Patrick M. Wilson
Victoria, BC Canada
