Good Day
Is it possible to connect an WD Red Drive (WD40EFRX) in a USB 3.0 case to the NAS System? Does it recognize the disk ntfs formatted with the whole capacity?
The goal is to use this external disk as backup with internal backup app. Need a 7x24 Disk because backup should run about every 1-2hours and copy new data to the external disk
thanks
andré
TS-469U RP USB 3.0 WD Red
- Don
Re: TS-469U RP USB 3.0 WD Red
Yes
Thanks Don
- schumaku
Why on earth use NTFS as a backup destination? Do you run backup or data export for portability?
why ntfs?
i use "backup station" > "external drive" to copy new data written to the nas to the external usb disk several times a day. if something happen to the nas, i can just plug the usb disk to a windows workstation and work with data from there...
- schumaku
That's data export, not backup.
yes but in the qnap software it is listed unter backup...
- schumaku
Hey, it's a perfect business continuation plan !
just connected the 4tb wd red in a external usb 3.0 case. works perfect
- Easy as a breeze
[previous two deleted posts reported as spam]
