I am using a QNAP TS-112 with the latest firmware installed and cannot seem to get the USB HDD connected to either the front or rear usb ports to be visible.
I have checked the drive on my Mac and it is functioning normally, however when trying to set up backup it isn't visible.
I have read around and run commands #lusb and #dmesg which gives the following information. I am a novice here so if there is any other information needed please let me know and I will investigate and provide information back. Im using a Hitachi 1TB Tourno external drive formatted as ExFAT.
[~] # lsusb
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[~] # dmesg
F330)
[ 9.596810] md: Skipping autodetection of RAID arrays. (raid=autodetect will force)
[ 9.604584] RAMDISK: gzip image found at block 0
[ 10.720035] VFS: Mounted root (ext2 filesystem) on device 1:0.
[ 10.726457] Freeing init memory: 168K
[ 10.933804] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 10.940427] orion-ehci orion-ehci.0: Marvell Orion EHCI
[ 10.945750] orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1
[ 10.981271] orion-ehci orion-ehci.0: irq 19, io mem 0xf1050000
[ 11.001229] orion-ehci orion-ehci.0: USB 2.0 started, EHCI 1.00
[ 11.011580] hub 1-0:1.0: USB hub found
[ 11.015366] hub 1-0:1.0: 1 port detected
[ 11.331253] usb 1-1: new high-speed USB device number 2 using orion-ehci
[ 11.338146] kjournald starting. Commit interval 5 seconds
[ 11.343706] EXT3-fs (sda1): mounted filesystem with writeback data mode
[ 11.461883] md: md9 stopped.
[ 11.483534] md: bind<sda1>
[ 11.498197] bio: create slab <bio-1> at 1
[ 11.502462] md/raid1:md9: active with 1 out of 1 mirrors
[ 11.508022] created bitmap (65 pages) for device md9
[ 11.531507] md9: bitmap initialized from disk: read 5/5 pages, set 0 of 132512 bits
[ 11.539722] hub 1-1:1.0: USB hub found
[ 11.551403] hub 1-1:1.0: 4 ports detected
[ 11.571417] md9: detected capacity change from 0 to 542769152
[ 11.612170] md9: unknown partition table
[ 12.984134] kjournald starting. Commit interval 5 seconds
[ 12.992210] EXT3-fs (md9): using internal journal
[ 12.996935] EXT3-fs (md9): mounted filesystem with writeback data mode
[ 13.311904] md: md13 stopped.
[ 13.333379] md: bind<sda4>
[ 13.348302] md/raid1:md13: active with 1 out of 1 mirrors
[ 13.354012] created bitmap (57 pages) for device md13
[ 13.366951] md13: bitmap initialized from disk: read 4/4 pages, set 0 of 114720 bits
[ 13.411294] md13: detected capacity change from 0 to 469893120
[ 13.441891] md13: unknown partition table
[ 14.058147] kjournald starting. Commit interval 5 seconds
[ 14.161785] EXT3-fs (md9): using internal journal
[ 14.166515] EXT3-fs (md9): mounted filesystem with writeback data mode
[ 14.578446] kjournald starting. Commit interval 5 seconds
[ 14.661576] EXT3-fs (md9): using internal journal
[ 14.666301] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 14.822265] kjournald starting. Commit interval 5 seconds
[ 14.941521] EXT3-fs (md13): using internal journal
[ 14.946335] EXT3-fs (md13): mounted filesystem with writeback data mode
[ 38.469653] NET: Registered protocol family 5
[ 38.841771] md: linear personality registered for level -1
[ 38.906728] md: raid0 personality registered for level 0
[ 38.983193] xor: measuring software checksum speed
[ 39.031223] arm4regs : 1090.800 MB/sec
[ 39.081220] 8regs : 758.800 MB/sec
[ 39.131222] 32regs : 904.800 MB/sec
[ 39.135423] xor: using function: arm4regs (1090.800 MB/sec)
[ 39.811359] raid6: int32x1 86 MB/s
[ 39.981318] raid6: int32x2 120 MB/s
[ 40.151299] raid6: int32x4 132 MB/s
[ 40.321383] raid6: int32x8 119 MB/s
[ 40.325152] raid6: using algorithm int32x4 (132 MB/s)
[ 40.330225] raid6: using intx1 recovery algorithm
[ 40.469176] async_tx: api initialized (async)
[ 40.721443] md: raid6 personality registered for level 6
[ 40.726786] md: raid5 personality registered for level 5
[ 40.732141] md: raid4 personality registered for level 4
[ 40.843047] device-mapper: ioctl: 4.22.1-ioctl (2012-06-01) initialised: dm-devel@redhat.com
[ 41.307106] MV-CESA:Fallback driver 'hmac(sha1)' could not be loaded!
[ 41.313621] alg: hash: Failed to load transform for mv-hmac-sha1: -2
[ 41.406599] cryptodev: driver 0.9 loaded.
[ 41.626950] usbcore: registered new interface driver usbhid
[ 41.632583] usbhid: USB HID core driver
[ 41.723846] usbcore: registered new interface driver usblp
[ 41.771003] sysinfo: Module loaded.
[ 42.054418] tntfs: module license 'Commercial. For support email ntfs-support@tuxera.com.' taints kernel.
[ 42.064056] Disabling lock debugging due to kernel taint
[ 42.170265] Tuxera NTFS driver 3013.7.24.6 [Flags: R/W MODULE].
[ 42.318239] Tuxera HFS+ driver 3013.5.18.4.5
[ 42.736956] RPC: Registered named UNIX socket transport module.
[ 42.743250] RPC: Registered udp transport module.
[ 42.748081] RPC: Registered tcp transport module.
[ 42.753031] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 43.160971] NFS: Registering the id_resolver key type
[ 43.425588] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 43.802334] fnotify: Load file notify kernel module.
[ 43.988599] lib80211: common routines for IEEE802.11 drivers
[ 43.994331] lib80211_crypt: registered algorithm 'NULL'
[ 44.123046] cfg80211: Calling CRDA to update world regulatory domain
[ 46.765717] usbcore: registered new interface driver snd-usb-audio
[ 46.835274] usbcore: registered new interface driver snd-usb-caiaq
[ 46.939388] Linux video capture interface: v2.00
[ 47.139350] uvcvideo: Unable to create debugfs directory
[ 47.171285] usbcore: registered new interface driver uvcvideo
[ 47.177065] USB Video Class driver (1.1.1)
[ 51.911079] eth0: mac address changed
[ 51.952432] eth0: link down
[ 51.955248] eth0: started
[ 53.523534] eth0: link up, full duplex, speed 100 Mbps
[ 64.242885] EXT2-fs (mtdblock5): warning: mounting unchecked fs, running e2fsck is recommended
[ 67.494483] kjournald starting. Commit interval 5 seconds
[ 67.531529] EXT3-fs (md9): using internal journal
[ 67.536253] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 71.635454] active port 0 :139
[ 71.638585] active port 1 :445
[ 71.641677] active port 2 :20
[ 75.219414] EXT2-fs (mtdblock5): warning: mounting unchecked fs, running e2fsck is recommended
[ 75.891720] md: bind<sda2>
[ 75.909307] md/raid1:md1: active with 1 out of 1 mirrors
[ 75.914754] md1: detected capacity change from 0 to 542851072
[ 76.991691] md1: unknown partition table
[ 79.322571] Adding 530124k swap on /dev/md1. Priority:-1 extents:1 across:530124k
[ 89.083227] EXT4-fs (sda3): Mount option "noacl" will be removed by 3.5
[ 89.083236] Contact linux-ext4@vger.kernel.org if you think we should keep it.
[ 89.083243]
[ 89.294911] ext4_init_reserve_inode_table0: sda3, 7441
[ 89.300084] ext4_init_reserve_inode_table2: sda3, 7441, 0, 0, 4096
[ 89.306375] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,noacl
[ 104.194538] eth0: stopped
[ 105.761986] eth0: link down
[ 105.764806] eth0: started
[ 107.540381] eth0: link up, full duplex, speed 100 Mbps
[ 122.782418] eth0: stopped
[ 122.810236] eth0: link down
[ 122.813060] eth0: started
[ 124.403173] eth0: link up, full duplex, speed 100 Mbps
[ 224.229883] active port 0 :139
[ 224.232992] active port 1 :445
[ 224.236055] active port 2 :20
[ 225.207335] warning: `proftpd' uses 32-bit capabilities (legacy support in use)
[ 246.647324] Initiate iscsi target log successfully.
[ 246.963888] iscsi_log_rcv_msg: get log pid = 6883.
[ 253.715477] EXT2-fs (mtdblock5): warning: mounting unchecked fs, running e2fsck is recommended
[ 279.600608] rule type=2, num=0
[ 280.908716] WOL disable
[ 307.686346] Loading iSCSI transport class v2.0-871.
[ 309.011627] iscsi: registered transport (tcp)
[ 310.002214] iscsid (8458): /proc/8458/oom_adj is deprecated, please use /proc/8458/oom_score_adj instead.
[ 345.451277] pic_ioctl: signal_pending current failed
[ 346.778871] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 346.786965] NFSD: starting 90-second grace period
[~] # exit
Kevin
