TS-670 Pro Cover Screws
A small matter. Just bought a TS-670 Pro. It's great. Then bought the 2 port expansion card. The three Phillips screws holding the back cover appear to be some special type. I have a large collection of standard spec Phillips screw drivers, but can not find one that will grip the screws. Can anyone advise on the screw spec or the driver required? These have a really shallow indent but are really tight. I'd really like to not jimmy them up. Thanks in advance.
Re: TS-670 Pro Cover Screws
If it is the same as 870, I use a #0 phillips head screwdriver.
Kevin
Kevin
TS-EC1080 Pro, TS-870, TS-870; 4.2.2 Build 20160901
