Hi
How can I find out the Samba version running on the latest firmware (4.1.3)
Cheers
SAMBA Version on QTS 4.1.3
- schumaku
Re: SAMBA Version on QTS 4.1.3
By checking the versions of the active smbd and nmbd for example?
[~] # ps -ef | grep mbd
8366 admin 4860 S /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/config/smb.conf
8410 admin 2076 S /usr/local/samba/sbin/nmbd -l /var/log -D -s /etc/config/smb.conf
[~] # /usr/local/samba/sbin/smbd -V
Version 4.0.21
[~] # /usr/local/samba/sbin/nmbd -V
Version 4.0.21
Please note: Your result can vary - the result depends on the NAS model line, and to some extent to the history of the installed HDD set and it's configuration carried forward. Some NAS models with operating on older configurations (ie migrated HDD sets) can be pushed to run SAMBA 4.
Version 4.0.21
Version 4.0.21
