I am trying to connect a USB-Stick to my QNAP 259pro+ but it seems the drivers are not available for this device.
connection should look like
/dev/ttyACM0
The USB Stick is a CUL433MHz from busware which i want to use for FHEM (home automation)
lsusb
Bus 004 Device 002: ID 03eb:204b Atmel Corp. LUFA USB to Serial Adapter Project
dmesg
[ 65.865027] e1000e 0000:02:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 65.869374] e1000e 0000:02:00.0: irq 45 for MSI/MSI-X
[ 65.869391] e1000e 0000:02:00.0: irq 46 for MSI/MSI-X
[ 65.869408] e1000e 0000:02:00.0: irq 47 for MSI/MSI-X
[ 65.982825] e1000e 0000:02:00.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:08:9b:cb:17:51
[ 65.988801] e1000e 0000:02:00.0: eth0: Intel(R) PRO/1000 Network Connection
[ 65.994802] e1000e 0000:02:00.0: eth0: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
[ 65.999949] e1000e 0000:03:00.0: Disabling ASPM L0s L1
[ 66.004308] e1000e 0000:03:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 66.008619] e1000e 0000:03:00.0: irq 48 for MSI/MSI-X
[ 66.008637] e1000e 0000:03:00.0: irq 49 for MSI/MSI-X
[ 66.008653] e1000e 0000:03:00.0: irq 50 for MSI/MSI-X
[ 66.115505] e1000e 0000:03:00.0: eth1: (PCI Express:2.5GT/s:Width x1) 00:08:9b:cb:17:50
[ 66.121642] e1000e 0000:03:00.0: eth1: Intel(R) PRO/1000 Network Connection
[ 66.129204] e1000e 0000:03:00.0: eth1: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
[ 66.140303] jnl: driver (UFSD_HEAD QNAP, LBD=ON) loaded at f87ac000
[ 66.149497] ufsd: module license 'Commercial product' taints kernel.
[ 66.154167] Disabling lock debugging due to kernel taint
[ 66.161272] ufsd: driver (UFSD_HEAD QNAP, build_host("BuildServer46-1"), acl, ioctl, bdi, sd2(0), fua, bz, rsrc) loaded at f8874000
[ 66.161279] NTFS support included
[ 66.161282] Hfs+/HfsJ support included
[ 66.161285] optimized: speed
[ 66.161288] Build_for__QNAP_Atom_x86_k3.4.6_2014-12-15_UFSD_HEAD_r243234_b51
[ 66.161291]
[ 66.237972] fnotify: Load file notify kernel module.
[ 67.305910] usbcore: registered new interface driver snd-usb-audio
[ 67.315419] usbcore: registered new interface driver snd-usb-caiaq
[ 67.326808] Linux video capture interface: v2.00
[ 67.347499] usbcore: registered new interface driver uvcvideo
[ 67.353243] USB Video Class driver (1.1.1)
[ 67.491221] 8021q: 802.1Q VLAN Support v1.8
[ 68.946930] 8021q: adding VLAN 0 to HW filter on device eth0
[ 69.032942] 8021q: adding VLAN 0 to HW filter on device eth1
[ 72.158040] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 80.431224] kjournald starting. Commit interval 5 seconds
[ 80.439270] EXT3-fs (md9): using internal journal
[ 80.443662] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 86.103377] md: bind<sda2>
[ 86.110126] md/raid1:md2: active with 1 out of 1 mirrors
[ 86.114801] md2: detected capacity change from 0 to 542851072
[ 87.124032] md2: unknown partition table
[ 89.177201] Adding 530124k swap on /dev/md2. Priority:-1 extents:1 across:530124k
[ 93.246380] md: bind<sdb2>
[ 93.254772] RAID1 conf printout:
[ 93.254780] --- wd:1 rd:2
[ 93.254787] disk 0, wo:0, o:1, dev:sda2
[ 93.254792] disk 1, wo:1, o:1, dev:sdb2
[ 93.254889] md: recovery of RAID array md2
[ 93.259452] md: minimum _guaranteed_ speed: 5000 KB/sec/disk.
[ 93.263998] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
[ 93.268942] md: Recovering started: md2
[ 93.273562] md: using 128k window, over a total of 530128k.
[ 99.352603] md: md0 stopped.
[ 99.365033] md: md0 stopped.
[ 99.537796] md: bind<sdb3>
[ 99.542702] md: bind<sda3>
[ 99.548351] md/raid1:md0: active with 2 out of 2 mirrors
[ 99.552868] created bitmap (233 pages) for device md0
[ 99.589486] md0: bitmap initialized from disk: read 15/15 pages, set 22 of 476550 bits
[ 99.621150] md0: detected capacity change from 0 to 1998792294400
[ 100.629637] md: md2: recovery done.
[ 100.634345] md: Recovering done: md2, degraded=1
[ 100.663115] RAID1 conf printout:
[ 100.663123] --- wd:2 rd:2
[ 100.663130] disk 0, wo:0, o:1, dev:sda2
[ 100.663135] disk 1, wo:0, o:1, dev:sdb2
[ 100.688542] md0: unknown partition table
[ 103.016558] ext4_init_reserve_inode_table0: md0, 14893
[ 103.020844] ext4_init_reserve_inode_table2: md0, 14893, 0, 0, 4096
[ 103.025105] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl
[ 133.360057] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 157.579235] warning: `proftpd' uses 32-bit capabilities (legacy support in use)
[ 167.709785] netlink: 12 bytes leftover after parsing attributes.
[ 167.716256] netlink: 12 bytes leftover after parsing attributes.
[ 167.722517] netlink: 12 bytes leftover after parsing attributes.
[ 177.244184] rule type=2, num=0
[ 178.439918] Loading iSCSI transport class v2.0-871.
[ 178.570263] iscsi: registered transport (tcp)
[ 178.637483] iscsid (9771): /proc/9771/oom_adj is deprecated, please use /proc/9771/oom_score_adj instead.
[ 178.734521] PPP generic driver version 2.4.2
[ 178.810708] PPP MPPE Compression module registered
[ 178.820859] PPP BSD Compression module registered
[ 178.872304] PPP Deflate Compression module registered
[ 178.934781] nf_conntrack version 0.5.0 (15955 buckets, 63820 max)
[ 179.024606] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 181.913181] tun: Universal TUN/TAP device driver, 1.6
[ 181.918126] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 182.559371] Set msys_nodify as 31743
[ 247.817273] usbcore: registered new interface driver usbserial
[ 247.823088] usbserial: USB Serial Driver core
[ 247.842190] usbcore: registered new interface driver ftdi_sio
[ 247.850097] USB Serial support registered for FTDI USB Serial Device
[ 247.860987] ftdi_sio 7-2:1.0: FTDI USB Serial Device converter detected
[ 247.868658] usb 7-2: Detected FT232RL
[ 247.874471] usb 7-2: Number of endpoints 2
[ 247.880260] usb 7-2: Endpoint 1 MaxPacketSize 64
[ 247.886194] usb 7-2: Endpoint 2 MaxPacketSize 64
[ 247.886201] usb 7-2: Setting MaxPacketSize 64
[ 247.907384] usb 7-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 247.912544] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 499.065989] usbcore: registered new interface driver dvb_usb_af9015
[ 499.404470] usbcore: registered new interface driver dvb_usb_dib0700
[ 499.444426] usbcore: registered new interface driver dvb_usb_rtl2832u
[ 499.492406] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 499.542533] usbcore: registered new interface driver it913x
[ 499.615320] usbcore: registered new interface driver dvb_usb_af9035
[ 499.647566] dvb-usb: found a 'WideView WT-220U PenType Receiver (Typhoon/Freecom)' in cold state, will try to load a firmware
[ 499.695460] dvb-usb: downloading firmware from file 'dvb-usb-wt220u-02.fw'
[ 499.754766] usbcore: registered new interface driver dvb_usb_dtt200u
[ 500.694930] usb 2-6: USB disconnect, device number 5
[ 500.698938] dvb-usb: generic DVB-USB module successfully deinitialized and disconnected.
[ 501.784038] usb 2-6: new high-speed USB device number 6 using ehci_hcd
[ 501.903550] usb 2-6: config 1 interface 0 altsetting 0 bulk endpoint 0x82 has invalid maxpacket 189
[ 501.911493] dvb-usb: found a 'WideView WT-220U PenType Receiver (Typhoon/Freecom)' in warm state.
[ 501.917234] dvb-usb: will use the device's hardware PID filter (table count: 15).
[ 501.921900] DVB: registering new adapter (WideView WT-220U PenType Receiver (Typhoon/Freecom))
[ 501.933840] DVB: registering adapter 0 frontend 0 (WideView USB DVB-T)...
[ 501.942827] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-6/input/input2
[ 501.947982] dvb-usb: schedule remote query interval to 300 msecs.
[ 501.954474] dvb-usb: WideView WT-220U PenType Receiver (Typhoon/Freecom) successfully initialized and connected.
[ 504.255157] dvb-usb: recv bulk message failed: -110
Kernel Version is:
uname -a
Linux QNAP 3.4.6 #1 SMP Tue Feb 17 05:33:10 CST 2015 i686 unknown
Hope someone can help.
Lisa08
