I got a problem when I plug the USB 3.0 Hubs to the port it cannot be boot up when I reboot the system.
In the screen will report no bootable disk....
When i plug the USB Hub without any device on the hubs...
I have try to use TP-LINK UH720 and Orico A3H7 both also have same issue...
Anyone can help me??
TS-470 USB 3.0 Hub
- pwilson
Re: TS-470 USB 3.0 Hub
The DoM on our NAS Model is a USB Device. The NAS needs the NAS DoM to be the first USB device detected, or it won't boot. Submit a ticket with the QNAP Helpdesk for advice on changes to the BIOS on the NAS to see if you can rectify this with BIOS setting changes.kenzkenz wrote:I got a problem when I plug the USB 3.0 Hubs to the port it cannot be boot up when I reboot the system.
I am successfully using an ST Lab USB3.0 Hub with my TS-470 Pro, but I suspect it works here because I played with the BIOS of the NAS. I do not recommend playing with the BIOS settings without guidance from QNAP, as incorrect settings could make the NAS "unbootable".
Patrick M. Wilson
Victoria, BC Canada
It is so sad listen that.....
Anyway thanks for your help, I have submitted the ticket for this issue....
I cannot found yours USB Hub in HK......
