one of the rear fans failed
as the original model was out of stock
replaced it by 92mm fan i already had
but it has different speed and cfm
so probably disturbing the air flow
can i make one fan push air and the other exhaust ?
or is it still more efficient to let them both exhaust ?
i feel like different speeds can cause turbulences
i ordered the original fan but don't know when it arrives
q:ts-670 replacement rear fan ?
- pwilson
Re: q:ts-670 replacement rear fan ?
I recently upgraded the Fan in my TS-470 Pro to a Noctua NF-B9 PWM 92mm (4-wire) fan.reiteravi wrote:one of the rear fans failed
Patrick M. Wilson
Victoria, BC Canada
thanks
i also used this one but as ts-670 has 2 fans the different speeds probably makes ventilation less efficient
i see 5-7 deg. rise to about 50 for the cpu (upgraded to i7)
and 45 for the hdd even while idle
- pwilson
reiteravi wrote:thanks
Please provide output for:
#!/bin/sh
# Check System and HDD Temperatures
echo "System Temperature: $(/sbin/getsysinfo systmp)"
echo "CPU Temperature: $(/sbin/getsysinfo cputmp)"
echo "HDD1 Temperature: $(/sbin/getsysinfo hdtmp 1)"
echo "HDD2 Temperature: $(/sbin/getsysinfo hdtmp 2)"
echo "HDD3 Temperature: $(/sbin/getsysinfo hdtmp 3)"
echo "HDD4 Temperature: $(/sbin/getsysinfo hdtmp 4)"
echo "System FAN1 Speed: $(/sbin/getsysinfo sysfan 1)"
echo "System FAN2 Speed: $(/sbin/getsysinfo sysfan 2)"
Patrick M. Wilson
Victoria, BC Canada
after 5 min no load:
[~] # echo "System Temperature: $(/sbin/getsysinfo systmp)"
System Temperature: 46 C/114 F
[~] # echo "CPU Temperature: $(/sbin/getsysinfo cputmp)"
CPU Temperature: 54 C/129 F
[~] # echo "HDD1 Temperature: $(/sbin/getsysinfo hdtmp 1)"
HDD1 Temperature: 35 C/95 F
[~] # echo "HDD2 Temperature: $(/sbin/getsysinfo hdtmp 2)"
HDD2 Temperature: 34 C/93 F
[~] # echo "HDD3 Temperature: $(/sbin/getsysinfo hdtmp 3)"
HDD3 Temperature: 33 C/91 F
[~] # echo "HDD4 Temperature: $(/sbin/getsysinfo hdtmp 4)"
HDD4 Temperature: 32 C/89 F
[~] # echo "HDD5 Temperature: $(/sbin/getsysinfo hdtmp 5)"
HDD5 Temperature: 32 C/89 F
- pwilson
Not very helpful without the Fan information. Try this instead:reiteravi wrote:after 5 min no load:
#!/bin/sh
echo "HDD6 Temperature: $(/sbin/getsysinfo hdtmp 6)"
echo "NAS Uptime: $(/usr/bin/uptime)"
#done
admin@NASTY2:~/bin# #!/bin/sh
admin@NASTY2:~/bin# # Check System and HDD Temperatures
admin@NASTY2:~/bin# echo "System Temperature: $(/sbin/getsysinfo systmp)"
System Temperature: 41 C/105 F
admin@NASTY2:~/bin# echo "CPU Temperature: $(/sbin/getsysinfo cputmp)"
CPU Temperature: 44 C/111 F
admin@NASTY2:~/bin# echo "HDD1 Temperature: $(/sbin/getsysinfo hdtmp 1)"
HDD1 Temperature: 32 C/89 F
admin@NASTY2:~/bin# echo "HDD2 Temperature: $(/sbin/getsysinfo hdtmp 2)"
HDD2 Temperature: 31 C/87 F
admin@NASTY2:~/bin# echo "HDD3 Temperature: $(/sbin/getsysinfo hdtmp 3)"
admin@NASTY2:~/bin# echo "HDD4 Temperature: $(/sbin/getsysinfo hdtmp 4)"
HDD4 Temperature: 31 C/87 F
admin@NASTY2:~/bin# echo "HDD5 Temperature: $(/sbin/getsysinfo hdtmp 5)"
HDD5 Temperature: -- C/-- F
admin@NASTY2:~/bin# echo "HDD6 Temperature: $(/sbin/getsysinfo hdtmp 6)"
HDD6 Temperature: -- C/-- F
admin@NASTY2:~/bin# echo "System FAN1 Speed: $(/sbin/getsysinfo sysfan 1)"
System FAN1 Speed: 1734 RPM
admin@NASTY2:~/bin# echo "System FAN2 Speed: $(/sbin/getsysinfo sysfan 2)"
System FAN2 Speed:
admin@NASTY2:~/bin# echo "NAS Uptime: $(/usr/bin/uptime)"
NAS Uptime: 10:17:48 up 12 days, 16:15, load average: 0.47, 0.41, 0.43
admin@NASTY2:~/bin# #done
I'm still using the original i3 processor:
cat /proc/cpuinfo | grep model\ name
model name : Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz
Patrick M. Wilson
Victoria, BC Canada
sorry slipped through cut/paste
on startup:
fan 1 607 (noctua)
fan 2 1180 (original)
after a few min
fan 1 1080
fan2 2140
also tried manual tuning the fans
a little better but fans are on higher rpm all the time
which is overkill
i might find another noctua and try with 2 identical fans
the noctua are usually more efficient and almost silent
on startup:
fan 1 607 (noctua)
after a few min
fan 1 1080
fan2 2140
which is overkill
- pwilson
Comparing just RPM doesn't prove a lot to be honest. It is really more about CFM. (Cubic Feet per Minute).reiteravi wrote:sorry slipped through cut/paste
on startup:
fan 1 607 (noctua)
after a few min
fan 1 1080
fan2 2140
which is overkill
Anyway, I'm not reading through multiple posts for this. You should have run the new script and provided the output. Seeing all the information in one place makes quoting it far easier as far as discussing it goes. I even re-wrote it for you to provide info from all 5 drives and both fans.
As long as the System and HDD temps are good you should be fine.
Patrick M. Wilson
Victoria, BC Canada
on startup:
System Temperature: 44 C/111 F
CPU Temperature: 48 C/118 F
HDD1 Temperature: 34 C/93 F
HDD2 Temperature: 33 C/91 F
HDD5 Temperature: 31 C/87 F
HDD6 Temperature: 0 C/32 F
System FAN1 Speed: 506 RPM
System FAN2 Speed: 1180 RPM
NAS Uptime: 21:17:39 up 1:45, load average: 0.18, 0.13, 0.13
after 5 min:
CPU Temperature: 51 C/123 F
HDD3 Temperature: 32 C/89 F
System FAN2 Speed: 1170 RPM
NAS Uptime: 21:24:41 up 1:52, load average: 0.53, 0.60, 0.34
with some load and manual fan spedd (loud)
System Temperature: 50 C/122 F
CPU Temperature: 61 C/141 F
System FAN1 Speed: 1625 RPM
System FAN2 Speed: 2521 RPM
NAS Uptime: 21:33:24 up 2:01, load average: 4.12, 2.40, 1.16
all this info is familiar and having modded my system i know the hardware limits
but having higher temperature than with stock fan is annoying
anyway thanks for your help , really
after 5 min:
