Hi
I have a TS659 Pro running firmware 4.2.0, running macOS
I also have a Powercom Imperial Series IMP1000AP and I can't seem to get the QNAP to recognise it...
I have run "lsusb" and it is recognised:
Bus 007 Device 006: ID 0d9f:0002 Powercom Co., Ltd Uninterruptible power supply
If I connect the UPS to my mac and run windows through fusion, I can see the UPS. So I am pretty sure that the usb cable is good.
But I cannot see it in the WebUI. I have researched this for hours on end, and have come up with no results. If anyone can help, I thank you in advance!
Ivan
[TS 659 Pro] UPS Not Detected
- Toxic17
Re: [TS 659 Pro] UPS Not Detected
Did you check the UPS is on the compatibility list for your model of NAS?
https://www.qnap.com/i/uk/compatibility ... category=9
if its on the list then Submit a Ticket with QNAP. if not you may ask them to add driver to support it, or go buy a supported UPS.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
Yes it is on the list
