I have TS-212 for some years already, and lately i started to hear the NAS's fan. Did anybody replace the fan to silent? Is any good model for replacement?
Thank you in advance
Dima
TS-212 fan replacement
- Toxic17
Re: TS-212 fan replacement
This has been discussed before on the forums but don't know if anyone actually replaced the fan.
You may need to remove the fan look at the specs/make model and then search google for a replacement. You could try asking QNAP by submitting a ticket and ask if they can supply you with a replacement fan, or advise you on what fan to buy for it.
Sent from my OnePlus X using Tapatalk
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
Thanx Simon,
i saw the discussion, but i didn't understand if anybody really replaced the fan. Someone talked about this one Evercool EC6015SH12BP http://www.ebay.com/itm/300859009884. It looks compatible, but i prefer to re-check if possible.
Thanx
Thanx
- Toxic17
smallnetbuilder done a review on it here: http://www.smallnetbuilder.com/nas/nas- ... s-reviewed
picture shows a serial for the fan.
Regards Simon
Qnap Downloads
Qnap Downloads
- schumaku
Compatibility is given by the 12 V, PWM (pulse width modulation RPM control), a tach sensor signal [thus four wires], the physical dimensions, and (harder/impossible to know) the max airflow at a nominal RPM, and the max RPM.
- Toxic17
yep until you strip it down and find any relevant info on the label on the fan its a bit hard to know.
Regards Simon
Qnap Downloads
Qnap Downloads
