I'm using an Inateck USB 3.0 SATA Adapter to temporarily attach HDDs to the TS-453mini. For convenience I tried to attach the adapter to the front USB port (which is set to "normal" mode, not quick copy). Still the HDD is not recognized. As soon as I attach the adapter to one of the USB ports in the back the drive is recognized.
When attaching to the front port the following error is shown in dmesg:
[870903.370404] hub 2-1:1.0: config error on port 2
[870904.482545] hub 2-1:1.0: Cannot enable port 2. Maybe the USB cable is bad?
[870904.502234] hub 2-1:1.0: config error on port 2
Regards
Sebastian
