[WD GREEN HDD COMPATIBILITY] Frustrated
Re: [WD GREEN HDD COMPATIBILITY] Frustrated
Postby QNAPJason » Thu Dec 03, 2009 7:27 pm
Hi lumi,
I am personally using a WD10EADS in my TS-219P. No problem so far.
Jason
Online Support Form: http://qnap.com/onlinesupport.asp
File Downloads: http://qnap.com/download.asp
HDD Compatibility: http://qnap.com/pro_compatibility.asp
Become a QNAP Fan: http://www.facebook.com/QNAPSys
QNAP TS-239 Pro II, 3.3.0 Build0607, 1TB x 1
Sony Ericsson Xperia X10 (Android 1.6)
HTC Touch Pro II (WM 6.5.3)
QNAPJason
Diamond Warrior
NAS Model: TS-219P
Postby STurtle » Thu Dec 03, 2009 10:57 pm
Taliska wrote:Guys,
Is WD saying that all their green drives are unsuitable in RAIDs, or is it just the 1.5Tb Greens?
WD themselves use the 1TB and 2TB Greens in their own My Book World Editions II's in RAIDed configurations...
Thoughts?
Taliska
Yes, that is what WD's support team implies. Here is an eMail that I received from WD support, when I specifically asked about the LCC issue only (which the received eMail does not mention at all :roll: ):
Thank you for contacting Western Digital Customer Service and Support. My name is Joan R.
Is this NAS device working on a RAID? If so, Western Digital manufactures desktop edition hard drives (Caviar Green) and RAID Edition hard drives. Each type of hard drive is designed to work specifically in either a desktop computer environment or a demanding enterprise environment.
If you install and use a desktop edition hard drive connected to a RAID controller, the drive may not work correctly unless jointly qualified by an enterprise OEM. This is caused by the normal error recovery procedure that a desktop edition hard drive uses.
When an error is found on a desktop edition hard drive, the drive will enter into a deep recovery cycle to attempt to repair the error, recover the data from the problematic area, and then reallocate a dedicated area to replace the problematic area. This process can take up to 2 minutes depending on the severity of the issue. Most RAID controllers allow a very short amount of time for a hard drive to recover from an error. If a hard drive takes too long to complete this process, the drive will be dropped from the RAID array. Most RAID controllers allow from 7 to 15 seconds for error recovery before dropping a hard drive from an array. Western Digital does not recommend installing desktop edition hard drives in an enterprise environment (on a RAID controller).
Western Digital RAID edition hard drives have a feature called TLER (Time Limited Error Recovery) which stops the hard drive from entering into a deep recovery cycle. The hard drive will only spend 7 seconds to attempt to recover. This means that the hard drive will not be dropped from a RAID array. Though TLER is designed for RAID environments, it is fully compatible and will not be detrimental when used in non-RAID environments.
I hope that we have met your expectations today and that you are satisfied with our service. If you have any further questions, please reply to this email and we will be happy to assist you further.
Sincerely,
Joan R.
Western Digital Service and Support
I have not yet encountered any problems whatsoever using two WD15EADS drives with RAID1 on a TS-219P.
However, as far as I understand the above eMail, the problem only arises once things go wrong. And then, it seems, waiting for 2-3 minutes and rebooting the NAS should resolve it, right?
Now I understand that such a procedure is totally against the intention of using RAID1, which is high availability, since then the data would be inaccessible until the reboot is finished. I guess this is what the WD support person is correctly worried about. However, this does not bother me, since I choose for RAID1 was backup-security only. I have learned now that RAID1 is the wrong solution for me personally, but I am a bit at a loss on how to switch from RAID1 to two single volumes (and then using a remote-replication-job to localhost) without moving all my data to third disk (which I do not have). So for now I stick with RAID1.
STurtle
Cadet
NAS Model: TS-119/219
Postby schumaku » Fri Dec 04, 2009 12:28 am
On a single disk unit, this should not hurt to badly - unless the eror recovery takes that long that the system watchdog is rebooting the QNAP TS. Or you do a big backup, or configure Q-RAID on a TS-1xx one day. The more disk activities there are, the more error recovery takes place - in fact more then what we users experience from outside.
Up to a certain manufacturing date and/or firmware version, it is possible to enable TLER on the WDC Green disks:
http://en.wikipedia.org/wiki/TLER
viewtopic.php?f=160&t=22554&p=96477&hilit=WDTLER.EXE#p96477
What is more then obscue in WDC's logic: More and more desktop systems come with RAID controllers, allowing shadowing or stripping of the local disks...
Under the line, it's pure money making - selling the same crappy product prone to massive errors under the hood under to different labels and price tags. According to reports, Western Digital WD15EADS 1.5TB Green Power drives firmware manufactured sinde November 2009 does no longer support TLER - and it can not be enabled with the WDTLER.EXE utility. So please take car of this fact. Honestly - if I'm uncertain, I would try to apply the configuration - worst case, the HDDs go back to warranty exchange making the lack of TLER and become _their_ problem. Fact is: There is no customer information or warning in the WDC products listing for "desktop drives" these drives are not RAID capable. This fact alone should allow anybody hurt by WDC (including QNAP...) to go back to the reseller, system integrator or distributor, and exchange to an alternate RAID-capable product. The WDC support e-mail cited in this thread is already the base for a legal case should they be unwilling. Take your customer rights!
There are reports saying "it works for me". Ha, indeed - I can also "confirm" some Samsung F1 firmware variants do "work" on one or the other configuration and installation. Until something changes! Aparently perfect running RAID drop the before good units while migration to bigger drives. A RAID must be rebuilt after a power failure or brute force shutdown. Any many other examples.
Regarding to WDC's own small RAID-NAS, it's very likely, they make use of a different firmware and/or configuration - or they simply delay any RAID operations during such events on one or the other disk.
Under this prospective, QNAP should phase-out WDC Green Power frome the support list - matter of fact it's WDC, and to some extent the other manufacturers of disks ruining the good name of the RAID manufacturers. Seagate is regularely making firmware updates available, for most Samsung F1 the 1117 firmware upgrades can be fecthed from Dell's support pages.
Just my 4cents.
-Kurt.
PS. Ignore any typos - ice cold hockey stadium here...
schumaku
Diamond Warrior
NAS Model: TS-509 Pro
Postby kanchelsis » Mon Dec 07, 2009 10:29 am
Just a quickie update that I've experienced no problems since I replaced my WD15EADS with the Hitachi 7k1000.B :D Performance is speedy and I'm truly happy for the first time in months since I bought my NAS and the HDDs.
That being said, some people experienced no-to-little problems with it (unlike me and others :( ). So it all comes down to luck I guess :roll: the problem seems to only occur if you RAID the disks.
@albundy: you could RAID the disks and test them out intensively over the next few days if they are ok. Else just return and exchange for other models.
NAS: TS-439 Pro, 4x7k1000.B.
WD**EADS is not stable for all revisions!
kanchelsis
Cadet
NAS Model: TS-439 Pro
Postby saunter » Mon Dec 07, 2009 2:53 pm
STurtle wrote:
Taliska wrote:Guys,
Thoughts?
Taliska
Sincerely,
Joan R.
Judging by the email from WD then it comes down to either us buying HDD that not the WD Green or QNAP themsevles to do something about these Green Drives not working well in RAID. As stated in the email above. From what I can see here in the forum, QNAP has done nothing or even mentioned about these Green drives not working well or MAY have issues with them, until this Thread was started. They listed them in the compatability list as supported drives and working fine. I believed that needs to be changed. Or at least mention about this issue and if the user wants to go ahead on their own accord then thats fine. I brought my drives based on that list and ** had nothing but issues with my NAS ( both times hardaware of the NAS failed, getting my 3rd tomorrow, hopefully all is well ). Will give the HDD another good test in the coming box and will post again on my results. But overall it completely ** to have 2 faulty TS410 and wasted a total of 5 weeks now just testing and waiting around for it to be shipped back to me. Complete waste of time.
saunter
Cadet
NAS Model: TS-410
Postby Broadsword » Wed Jan 20, 2010 9:41 pm
Well based on the compatibility list I paid £300 for 4 1.5TB EADS.
I have started having real problems with the device now, pauses and stutters during media playback, large media files that report as fully copied to the NAS actually being a few GB less than it should have been and very very slow access to files via explorer and the GUI whilst anything else is happening. The logs show constant disconnections etc.
Quite obvious it is the drives.
I honestly can't believe, and quite frankly it leaves a very bad taste in my mouth, that QNAP were aware of these issues as far back as last summer and did not remove these drives from the list a lot sooner.
I have until 31 Janu to return the QNAP and based on this thread I probably will do, Synology here I come. :|
Broadsword
Cadet
NAS Model: TS-410
Postby schumaku » Thu Jan 21, 2010 12:32 am
Broadsword wrote:Well based on the compatibility list I paid £300 for 4 1.5TB EADS.
Swap the crappy WD Desktop drives (well crappy Deep Error Recovery firmware feature in fact, the hardware is ok...) - these do not work on any other comparable NAS in the market. Frustration understood - in first priority, this is a WDC issue. It is WDC having changed the specifications, and removed the ability to enable TLER, by removing the TLER code from their Desktop drives - leaving you, dear anyNAS customers with WD Desktop drives, lost in space.
Sorry, I try warning repeatedly here in the forum.
-Kurt.
schumaku
Diamond Warrior
Postby restock » Thu Feb 04, 2010 9:35 am
Well - I picked up a QNAP TS410 with 4 x 1.5TB WD Green drives for a 5 bay RAID array. Looks like I may have to exchange the drives for new ones now. Any suggestions for 1.5TB or 2TB drives? Hitachi? Seagate?
restock
Cadet
NAS Model: TS-410
Postby Broadsword » Thu Feb 04, 2010 6:45 pm
restock wrote:Well - I picked up a QNAP TS410 with 4 x 1.5TB WD Green drives for a 5 bay RAID array. Looks like I may have to exchange the drives for new ones now. Any suggestions for 1.5TB or 2TB drives? Hitachi? Seagate?
What issues are you suffering?
I went for Samsung F2 H15JUI (or similar, cant recall the exact name) 1.5TB drives. And so far, about 1 week in have had no issues. But I had no issues 1 week in using the WD drives either so I'm still on edge about the whole thing.
Broadsword
Cadet
NAS Model: TS-410
Postby fordy » Wed Feb 24, 2010 7:30 am
I think I'm experiencing an issue because of this.
I got some brand new 1.5GB WD Greens to put in the NAS, and all seemed to be good to begin with (apart from initially not being seen on the network for awhile on startup)
Now all of a sudden, the NAS needs to delay about 30 seconds or so each time I go into a subdirectory, plus the web interface hangs for the same amount of time. The network map also constantly shows up as being disconnected, too.
When copying from/to the NAS, the initial transfer is nice and fast, and then it gets to a random point where it just stops, hangs for a moment and then reports that the network connection was lost.
I have ruled out network issues, since I have tried multiple CAT5E and CAT6 cables, different switches and even direct linking to a workstation.
fordy
Cadet
NAS Model: TS-410
PreviousNext
Return to Hardware & Software Compatibility
Who is online
Users browsing this forum: No registered users and 4 guests
