TS-669 Pro and Vantec NexStar 400MX-S3R eSATA enclosure
Hello QNAPers,
I am attempting to attach a Vantec NexStar 400MX-S3R to my 669 Pro as an external backup drive and, for some reason, the QNAP is not recognizing the eSATA connection. Is there anything required to enable eSATA support? If I use the USB 3.0 connection it seems to work fine.
bT
bT
Reason: Changed topic from "TS-669 Pro and eSATA" to "TS-669 Pro and Vantec NexStar 400MX-S3R eSATA enclosure"
TS-669 Pro * HP StorServ 7000 * Vantec NexStar MX
- pwilson
Re: TS-669 Pro and eSATA
bittwiddler wrote:Hello QNAPers,
bT
What SATA controller chip does your Vantec NexStar 400MX-S3R use? Does it use FIS signalling? I don't see your external multidrive USB3.0/eSATA Enclosure listed on the QNAP External Storage Device Compatibility List.
Patrick M. Wilson
Victoria, BC Canada
Hi Patrick,
You are correct. The Vantec does not appear on the list of external multidrives not known not to work. However, eSATA is a standard. Perhaps I should ask which version of eSATA the 669 supports. The Vantec manual only says:
- For eSATA Speeds, System Must Support eSATA Specifications
- For eSATA, System Must Support Port Multiplier
I suspect the last item may be the rub.
Cheers
Cheers
- pwilson
Yes eSATA is a standard. QNAP Firmware has only limited support for eSATA-PM however, hence the question on the eSATA chip used by your Vantec. Does it use FIS–based (frame information structure) switching? If it doesn't then it isn't compatible.bittwiddler wrote:Hi Patrick,
Cheers
Patrick M. Wilson
Victoria, BC Canada
Patrick, Vantec doesn't disclose that bit of information anywhere or I would have answered your question straightaway. I'll stick with USB 2.0 for now.
Thank you for clarifying what is supported and what is not.
Cheers
Cheers
- pwilson
Yeah. That's a shame as they make quality hardware. I unfortunately don't own one of these, so I can't simply pop the cover and look.bittwiddler wrote:Patrick, Vantec doesn't disclose that bit of information anywhere or I would have answered your question straightaway. I'll stick with USB 2.0 for now.
Cheers
Patrick M. Wilson
Victoria, BC Canada
I have no problem popping the cover. I live in the embedded world so I am at home there. I figured that stuff was implemented in the PM stack or in an unlabled ASIC. Should I be looking for a chipset or a CBS/FIS jumper?
bT
bT
- pwilson
No idea. I don't own one of these, so I can't tell you anything about it.bittwiddler wrote:I have no problem popping the cover. I live in the embedded world so I am at home there. I figured that stuff was implemented in the PM stack or in an unlabled ASIC. Should I be looking for a chipset or a CBS/FIS jumper?
bT
Patrick M. Wilson
Victoria, BC Canada
Re: TS-669 Pro and Vantec NexStar 400MX-S3R eSATA enclosure
Patrick, I figured I'd cut to the chase so I called Vantec directly. They confirmed that they support CBS only.
- pwilson
That is unfortunate. On the other hand, you should be able to use it under USB, so it shouldn't be a complete loss.bittwiddler wrote:Patrick, I figured I'd cut to the chase so I called Vantec directly. They confirmed that they support CBS only.
Thanks for taking the time to share this unfortunate news with us. Hopefully this will help other people considering this device.
Patrick M. Wilson
Victoria, BC Canada
It is a great little device and is small enough to store in a safe, SCF, etc. Just remember to use the USB 3.0 port on your NAS and it will really scoot!
Update: I have been using 2 of these devices on the USB 3.0 ports and they are working very well. Fast, cool, and reliable.
However, I added a third enclosure on USB 3.0 and now my QNAP is calling it USBDisk2 instead of USBDisk3. So, two of the enclosures now have the same name. I cannot find any way to force the name to change.
- schumaku
In general, to address the same external storage under the same shared folder name - put a labels on each of the file systems.
It's somewhat hidden in the forum (and probably documented nowhere beyond): Unless I'm very wrong, QNAP does only support one external storage device per port, and no USB hubs. As there are only two USB 3.0 ports ... Give it a try and temporary plug #3 on a dedicated USB 2.0 port.bittwiddler wrote:However, I added a third enclosure on USB 3.0 and now my QNAP is calling it USBDisk2 instead of USBDisk3. So, two of the enclosures now have the same name. I cannot find any way to force the name to change.
sorry for the confusion. #1 and #2 are running on USB 3.0 and #3 is running on USB 2.0. Sorry. I am unable to find where to add the labels to each of the filesystems. Each enclosure is formatted as EXT4.
BTW, I am using these drives for Backup Station as backup to an external drive. Each backup job needs to be able to reference the drives in a unique manner.
bT
bT
This stuff is really flakey. I just powered down #3 and now the NAS is showing both #1 and #2 as USBDisk1.
I am running version 4.0.7.
bT
bT
