hi,
hope i m in the right forum.
first:
i have TS-469L 4 bays but with 2 HHD 3TB WD green, liner disk.
i made a mistake today and got myslef locked out my NAS.
i recently made my NAS accessible from outside my local network via SSH.
today i saw a lot of brute force attempts to login.
so i searched around and notice that in the security tab there is an option to create a white list of ips.
i enter my local network ip rang and press apply.
BUT i mistake and enter
192.168.1.0 - 192.168.1.20
this is not my subnet
my network is on 192.168.0.0-20
is there a way to change login to the box without changing my router settings/reset to factory?
thanks.
locked out my NAS.
- Don
Re: locked out my NAS.
Read the manual on performing a reset.
thanks for the fast reply,
is that mean i will lose all my data?
can you send a link to the manuals please.
thanks
thanks
- doktornotor
I'm gone from this forum till QNAP stop wasting volunteers' time. Get help from QNAP helpdesk instead.
Warning: offensive signature and materials damaging QNAP reputation follow:
QNAP's FW security issues
QNAP's hardware compatibility list madness
QNAP's new logo competition
Dear QNAP, kindly fire your clueless incompetent forum "admin" And while at it, don't forget the webmaster!
- pwilson
If reading the fine manual doesn't work, you might try using the Advanced search at the top of every page of the Forum to find one of the 13768 pre-existing messages about this issue.
Patrick M. Wilson
Victoria, BC Canada
- schumaku
Manually configure a computer interface to this other TCP/IP network address range, reconfigure the NAS, and revert the computer i.e. to DHCP or it's original settings. Much less work than a reset.bid wrote:i enter my local network ip rang and press apply.
Good luck with this approach should you ever intend to access the NAS from remote, from a mobile App, ...
If you don't need SSH access from the outside world (ie. for ssh access or ssh'ed rsync) - consider to avoid the SSH port to the Internet on your router.
hi,
thanks guys, next time i will improve my search skill's before positing. (the forum UX is not that cool)
i reset (press for 3 seconds) that did the trick,
the other solution (if i understand it right) was to change the IP of another PC on the network, i didn't try it.
have a good day/night.
