Can I replace the stock fans with these?
http://www.sidewindercomputers.com/pa92mesp.html
What are the specs of a replacement fan (Voltage, Amperage, etc)?
System Fans for QNAP TS639 Pro
- QNAPJason
- QNAP Staff
Re: Replace fans on 639 device
Hi yadaa,
It's not recommended to replace the stock fans as we've tested a variety of fans and found the current one to be more stable and reliable.
The TS-639 uses 2x 90mm FANs, +12V, 4pin connector
Hi guys,
I tried googling but couldn't find an answer on the web and the QNAP support guys were not very useful.
The specs for the QNAP TS639 PRO (and likely other Qnap models) are for 2x 90mm system fans.
I have just replaced and can confirm that 92mm Noctua NF-B9 PWM fits perfectly (make sure PWM) and plugs in very nicely (no need for the extension cables). It has 4 connectors and the fan speed is correctly identified by the QNAP OS (4.1.0 firmware). These fans also come with nice silicon mounts which can be used instead of the screws and allow the fan to 'float' on the silicon to reduce noise.
[~] # getsysinfo sysfan 1
522 RPM
[~] # getsysinfo sysfan 2
524 RPM[~] #
Hopefully this will be useful for someone in the future.
Cheers
522 RPM
524 RPM[~] #
Cheers
- pwilson
Re: System Fans for QNAP TS639 Pro
Thanks for sharing, and further thanks for supplying your subsequent troubleshooting effort to ensure they were working. Much appreciated.mseddon wrote:Hi guys,
522 RPM
524 RPM[~] #
Cheers
Patrick M. Wilson
Victoria, BC Canada
I did this because one of the fans reported a error.
When I restarted the system both fans were working again, but since they are 6 years, I decided to replace them both anyway.
I used 92mm x 92mm x 25mm 4pin PWM arctic cooling fans, they are working fine. I would expect any fan fitting those specs would be fine.
http://www.arctic.ac/worldwide_en/arctic-f9-pwm-co.html
Thanks for the tip on the 4pin connector.
I used 92mm x 92mm x 25mm 4pin PWM Arctic Cooling fans from NCIX, they are working fine.
875 RPM
820 RPM
875 RPM
820 RPM
