My TS-219P is suddenly dead...
I switched off the qnap, pulled out the power adaptor and installed 2 new WD60EFRX drives and booted up the qnap.
The qnap stayed dead
No ethernet led, no power led.
I measured the voltage of the adaptor (12V/5A) that one works.
Does anyone have bright idee's, to get my qnap alive again????
Greeting from Andre
the Netherlands
TS-219P suddenly dead
- doktornotor
Re: TS-219P suddenly dead
Get a new power adaptor? (Yeah, I read you measured it.)
I'm gone from this forum till QNAP stop wasting volunteers' time. Get help from QNAP helpdesk instead.
Warning: offensive signature and materials damaging QNAP reputation follow:
QNAP's FW security issues
QNAP's hardware compatibility list madness
QNAP's new logo competition
Dear QNAP, kindly fire your clueless incompetent forum "admin" And while at it, don't forget the webmaster!
- pwilson
QNAP TS-219P Accessories Store:wapos wrote:My TS-219P is suddenly dead...
Greeting from Andre
the Netherlands
Power adaptor for 3.5- inch 2 Bay & 2.5-inch 2 Bay NAS $83.00 USD.
Patrick M. Wilson
Victoria, BC Canada
Hi Patrick, thank you for your answer, but i measured the adaptor and its output is 12v (with a high resistance multimeter )
Do you still think the adaptor could be the problem?
Thanks for answering !
Gr. Andre
Gr. Andre
- pwilson
It is still the most likely cause. Test your HDD's using the manufacturers Diagnostics software, if you suspect that it is a drive issue instead. If the drives pass, then you are back to suspecting the PSU.wapos wrote:Hi Patrick, thank you for your answer, but i measured the adaptor and its output is 12v (with a high resistance multimeter )
Gr. Andre
Patrick M. Wilson
Victoria, BC Canada
- itsmarcos
- Easy as a breeze
Try the following:
1. Put a different HDD in the NAS and check if it boots.
2a. If (1) failed, check for power supply issues or for NAS issues
2b. If (1) succeeded, try powering it up with one of your new HDDs (try both HDDs but one at a time).
3a. If both HDDs failed in (2b) this should be a NAS-HDD model compatibility issue
3b. If only one of the two HDDs fails then you have a seriously faulty HDD and consider replacement.
4. If using both new HDDs fails then this should be a compatibility issue
Keep us posted
Keep us posted
Primary
QNAP TVS-951N [latest QTS 5.0.x]
- disk 1: WDC Red WD80EFZX
- disk 2: WDC Red WD80EFZX
- disk 6: Samsung SSD Evo 500GB, SSD Cache
- disk 7:Samsung SSD Evo 500GB, HybridMount Cache
- External disk: WDC Red WD60EFRX
Dead one
QNAP TS-253B [4.4.x] - now dead
Remote backup
QNAP TS-219 P+ [latest 4.3.x]
- disk 1: HGST Deskstar 7K3000 HDS723030ALA640 3TB
- disk 2: WDC Red WD40EFRX
Hello itscarlos,
thank you for taking youre time to answer my question...
But as i already wrote, the nas plays dead, meaning no leds are lighting, no fan is spinning.
Two minutes before with the old HD in it he worked (for 4 years now, with no problems) and now suddenly (after changing to new HDs) he does not boot anymore.
But, today is a new day, i wil call qnap.nl
