Hello QNAP community,
I am currently planning to supplement my TS-419 P2 NAS with a Raspberry Pi B+. This little bugger wants ~700mA of amperage power supply.
Out of curiosity, I am wondering:
would the USB port of the TS-419 P2 provide enough power for the Rasp Pi? Is power on its USB port kept online even if the NAS has entered sleep mode?
I do already know that the QNAP's USB does provide some amperage, as it should according to the USB standard. Nevertheless, it would be great if the device
interpreted the standard as losely as most machines do, and supply some decent amperage to the USB.
I would really appreciate any information, especially if somebody already tried this rather obscure approach
Thank you
DrGlitch
TS-419 P2 / USB power supply
- Don
Re: TS-419 P2 / USB power supply
For that type of technical info I suggest you contact QNAP support directly as this is a community forum and QNAP rarely participates.
Sent from my iPad using Tapatalk HD
- pwilson
I have no idea if it is rated for it, but I successfully plugged a Raspberry Pi into the USB2.0 port on my TS-419P+ when I was running it. I don't believe it shutdown when the NAS entered "sleep", however I run my NAS 24/7/365, so I don't exactly monitor whether or not it is sleeping.DrGlitch wrote:Hello QNAP community,
I can't however answer any questions as I no longer own my Raspberry Pi nor my TS-419P+.
Patrick M. Wilson
Victoria, BC Canada
- schumaku
The ARM NAS like the TS-419P II don't have a sleep mode in the sense of a ACPI modes - only the HDD are spin-down of not used for a while.DrGlitch wrote:Is power on its USB port kept online even if the NAS has entered sleep mode?
Ah, thank you for the hint! I did not quite realize this at first, it now appears just logical to meschumaku wrote:The ARM NAS like the TS-419P II don't have a sleep mode in the sense of a ACPI modes - only the HDD are spin-down of not used for a while.
Hello Community!
It's been a while since I started this thread. I now had the opportunity to try this for myself and it works just as expected
That's another happy li'l machine in the herd...
