Shutdown both NAS devices. Swap PSU's between units. Start up both devices again. I bet this time the TS-219P will startup without issue, and the TS-219PII will fail.luhewiese wrote:Hello out there,
I have a TS-219P and in my DMZ a newer one TS-219PII, both with two similar drives in RAID 1 each.
Coming back from work today I found my TS-219P not working anymore: no fan, no lights, no running drives although electricity is on.
I would like to check, if the disks of that NAS are still ok and data is there.
My question: can I replace the disks of the second NAS by the disks from the broken NAS and continue working with that one - or is the NAS formatting every new disk inserted?
The same question would occur when I by a new NAS without disks and try to put the disks of the old NAS in it. There are already slightly differences in the file system between my two models (e.g. Qmultimedia vs Multimedia).
thanks for your help
If this works as described, simply replace the failed PSU. (Troubleshooting 101).
