My TS-412 began to restart itself and gets stuck at start up. but when I remove all the disks it restarts with no problem.
If I insert a disk only (any one of the disks) she recognizes them and does not restart.
If I insert all 4 disks it restarts immediately.
If I insert the disk 2 with another disk it restarts immediately.
If I insert disks 1 and 4 does not restart the NAS.
If I insert the disks 1, 3 and 4 it restarts but not immediately.
With 1 and 4 like i said does not restart but when i awake it from sleep mode i restarts itself again..
I tested all the drives on my pc and pass all tests without problems.
I assume that disc 2 is defective despite passing all the tests that I do.
Is it possible that all of my discs are damaged?
Why she's recognizing all discs without problem but can not be inserted into the 4 simultaneous?
How can i recover my data?
Can i read the data from this raid on my pc?
TS-412 problems
- pwilson
Re: TS-412 problems
Data recovery is simple: "Restore from your most recent Backup". See the Backup Station section of the fine manual for details on restoring your archival Backups.paqmac wrote:Hello,
I assume that this defective disc 2 despite passing all the tests that I do.
Is it possible that all my discs are damaged?
Why is in recognizing all discs without problem but can not be inserted into the 4 simultaneous?
It is likely that only one drive that is damaged, (unless you are using strongly discouraged drives like Seagate DL or DM-series drives). Unfortunately you have not provided enough information for us to help very much. Please review: When you're asking a question, please include the following.
- Was the HDD LED above any of your drives solid Red?
- Can you access the NAS via SSH w/o drives? (login with "admin"/"admin").
Patrick M. Wilson
Victoria, BC Canada
