May I kindly ask to support Edimax IC-3116W IP Camera? Sorry for asking in this topic, but I don't know where is proper place.
Or maybe someone could send some advices how to connect that camera using common settings (or other type of camera)? Is it possible?
It seams it is newer model already supported Edimax IC-3115W, but setting from that one are not working (nor from other Edimax branded cams).
Below link to camera spec:
http://www.edimax.com/edimax/merchandis ... /ic-3116w/
Thanks very much,
Kris.
Re: Edimax IC-3116W IP Camera
Does anyone know how to configure that camera (Edimax IC-3116W) in Surveillance Station?
Thanks,
Kris
Thanks,
Kris
- andrewyu
Please check http://www.qnap.com/i/cht/product_x_gra ... p?g_cat=18.
We didn't support this camera now.
You can refer to Generic Methods to Add IP Cameras to try.
Best regards,
Andrew
Andrew
