Can access smb/cifs share via windows, cannot via linux
TS559 here, latest firmware.
I can login via windows explorer and see correctly the password protected shares, this is impossible via linux. mount.cifs fails with "access denied" and a login failure is logged on the 559.
IPs are whitelisted, username and password have been double and triple checked.
Any help is greatly appreciated.
- schumaku
Re: Can access smb/cifs share via windows, cannot via linux
Impossible to provide any help as-is. Show real details - for some 3.1, for some 3.8.1, for some 4.x is the latest firmware.
Then, provide the details of the mount, the mount command, the content of the fstab, ...
Probably using "critical" characters in the authentication, or whatever.
Right, so:
- It's firmware 3.8.1
- mount command and results
- password is made of lowercase characters, no digits, no special characters, no punctuation or whitespace
- what I get with smbclient with a proper user (smbtest) and with a fake user
I hope this is enough to better understand the problem.
Thanks for your help.
# mount.cifs //nas1/test nfs --verbose -o user=smbtest
Password:
mount.cifs kernel mount options: unc=//nas1\test,ver=1,user=smbtest,ip=192.168.170.51,pass=********
mount error(13): Permission denied
# smbclient -L nas1 -U smbtest
Enter smbtest's password:
session setup failed: NT_STATUS_LOGON_FAILURE
# smbclient -L nas1 -U blah
Enter blah's password:
Domain=[SERVICES] OS=[Unix] Server=[Samba 3.5.2]
Sharename Type Comment
IPC$ IPC IPC Service ()
test Disk asdfasdf
Network Recycle Bin 1 Disk [RAID5 Disk Volume: Drive 1 2 3 4]
Public Disk System default share
Usb Disk System default share
Web Disk System default share
Recordings Disk System default share
Download Disk System default share
Multimedia Disk System default share
Server Comment
NAS1
NSIM
Workgroup Master
SERVICES NSIM
- schumaku
Well, review your mount, review your mount point, ...:
root@kurt-ubuntu:~# mkdir /mnt/cofs
root@kurt-ubuntu:~# mount -v -t cifs //ts-459proII/Download /mnt/cifs -o user=myusername
Password:
mount.cifs kernel mount options: ip=10.10.1.138,unc=\\ts-459proII\Download,user=myusername,pass=********
//ts-459proII/Download on /mnt/cifs type cifs (rw)
Password:
I found out, this works:
The mount command is ntlmv2 capable... I don't understand why it doesn't even try without the explicit option, doesn't make sense to me.
mount.cifs //nas1/test nfs --verbose -o user=smbtest,sec=ntlmv2
- schumaku
Well, in general you should use mount - instead of calling the mount.helper direct
Configured "Allow only NTLMv2 authentication" on the NAS Network Services >> Microsoft Networking >> Advanced Options ?
Exactly. I set NTLMv2 only and the samba client didn't negotiate its use even if it worked ok when forced. As I said, it doesn't make sense to me at all to fail miserably where it could succeed: a silent security downgrade is bad but an upgrade is not.
Of course in fstab I'll be using the default mount option but I wanted to use the lowest level command possible to avoid any possible confusion about the nature of the problem.
Thanks anyway for your help.
- pwilson
There are multiple possible ways to connect a Linux machine to the NAS, but using SAMBA shares is by far the most reliable. Gigabit all around on this network. To keep it easy to manage, I simply create empty folders in the "/share" directory on my Ubuntu box, that I can mount to.Darknight7 wrote:TS559 here, latest firmware.
I create subfolders within "/share" called "Public", "Download", "Multimedia", etc. (on my Ubuntu boxes)
sudo mkdir -p /share/Multimedia
sudo mkdir -p /share/Public
sudo mkdir -p /share/Download
sudo mkdir -p /share/Web
I then simply mount my NAS shares onto these directories by modifying my "/etc/fstab" on my Ubuntu box to include the following lines:
My /etc/fstab file on my Ubuntu includes the following lines:
//nas/Multimedia /share/Multimedia cifs defaults,rw,credentials=/etc/nas-credentials
//nas/Public /share/Public cifs defaults,rw,credentials=/etc/nas-credentials
//nas/Download /share/Download cifs defaults,rw,credentials=/etc/nas-credentials
//nas/Web /share/Web cifs defaults,rw,credentials=/etc/nas-credentials
username=pwilson
password=DjD05$@Fwpfd
sudo chmod 600 /etc/nas-credentials
sudo mount -a
Remember to create the "mount points" on your Ubuntu box so that they is somewhere to mount to:
I still use QNAP tools like Web File Manager, etc when I'm away from my network, but when I'm at home, I can literally use "cp" and "mv" commands to copy/move files between my NAS and my local machine. No fancy tools required. I don't use NFS at all on my Linux machines, everything is connected by SAMBA. (Even my XBMC-HTPC's, XBMC-xboxes, and Boxee Boxes access the NAS via SAMBA). I can even "drag & drop" like a Windows user, using "nautilus" or "dolphin" if I feel so inclined.
I do use NFS on my NAS, but only as part of my PXE server, so that I can load Linux Live-CD's via PXE (with nfsboot/nfsroot options) on new machines when I introduce them to my network. I am able to access all my internal Websites on my NAS from Firefox on my Ubuntu boxes. Only challenge is Surveillance Station, as it requires "IE" which Ubuntu doesn't have. Everything else works properly. In fact I am so happy with this setup, that I no longer own a Windows machine. All my Linux boxes are running under either Ubuntu or BackTrack5. (I use the same "/etc/fstab" entries (and "/etc/nas-credentials" file) on all of my Linux boxes).
Very easy to use, and very easy to manage. My girlfriend, and my children are still using Windows machines, but I personally do not. All our PC's and Smartphones can access the NAS, even remotely. It is a beautiful thing....
Patrick
Patrick M. Wilson
Victoria, BC Canada
I had the same problem here with my TS469pro, and I found the solution. It might work for the original poster, too.
If only Linux clients are affected, it's sufficient to set the following in /etc/samba/smb.conf on the clients:
If there are ther clients that can't login either, it may be necessary to change the configuration of the NAS server, as follows: Log in via ssh as admin to your NAS box, and edit /etc/config/smb.conf (using vi /etc/config/smb.conf), adding the following line in the global section at the top:
After saving the file, restart the smb service with /etc/init.d/samba4.sh restart.
Background: QNAP NAS servers don't allow the weaker NTLMv1 protocol by
default (only NTLMv2). But smbclient uses this protocol unless "client
ntlmv2 auth = yes" is set. Older or dumb clients (in my case, a SAT
receiver) can only do NTLMv1 anyway and thus they need the setting in the NAS server.
client ntlmv2 auth = yes
ntlm auth = yes
- schumaku
Hello, and welcome to the QNAP NAS Community Forum!
By default, the QNAP NAS does permit (certainly up to QTS 4.1.1) both NTLM(v1) and NTLMv2 authentication from the client. There is no need to edit anything - use the Control Panel -> Network Services -> Win/Mac/NFS -> Microsoft Networking -> [Advanced] controls:
Here the (non-default) "Allow NTMLv2 auth only" is ticked.
Further on, the /etc/init.d/samba4.sh is obsolete (and should no longer exist on any QNAP NAS, it's only a remaining fractal on the TS-509/809/x39/x59 - all these NAS models currently not supporting SAMBA4). Use /etc/Init.d/smb.sh instead.
Regards,
-Kurt.
Regards,
-Kurt.
Thanks for pointing this out. I will try the advanced settings. It is strange though that NTLMv2 was disabled on my NAS (it definitely was, and I hadn't changed the setting, this box was essentially brand new). I just thought that this setting might be a good explanation for someone being able to log in from Windows but not with smbclient. In a modern Windows environment, disabling NTLMv1 makes a lot of sense.
Oops, just discovered that you had discussed this already 2 years ago. I had scanned over this thread but concentrated on the beginning and end, missing the important information in the middle. Sorry for the noise.
- pwilson
Probably earlier than that too. Advanced search is your friend. (Top right corner of every page on this Forum).mwilck wrote:Oops, just discovered that you had discussed this already 2 years ago. I had scanned over this thread but concentrated on the beginning and end, missing the important information in the middle. Sorry for the noise.
I've been mounting Linux shares via SMB/CIFS for over 20 years here, including doing so on my Linux boxes.
I also use SMB to mount my NAS on my Android devices. I've heard rumors that Windows users use it too. Even Apple has finally started to migrate from their painfully broken AFP protocol to SMB/CIFS. Hopefully one day AFP and NFS will be nothing more than bad memories. (I stopped using NFS in 1991, even though most of my computers run Linux).
Patrick M. Wilson
Victoria, BC Canada
Guys correct me if I am wrong but I just build a xenology box on a pc and everything works perfect with my Linux Mint accessing Samba shares via the network browser.
I have 2 ts-451 and one ts-230 none will work browsing the network share via the browser.
I called Qnap support which was useless. They say other than connecting via the smb\\ ip or name they don't support network browsing the shares. I know this had worked before and it has been proven that my Linux pc works since I can connect to the xenology via the Linux pc browser.
QNap like many times have broken something via a hot fix or something with Samba.
and we all need to complain for a fix
- OneCD
