vSphere VAAI plugin
vSphere VAAI plugin
Hi @ll
I want to use the VAAI feature. On the download side I've found the QNAP_QNPNasPlugin_1.0.zip (contains the .vib file). What shall I do with it? I assume I have to install it on the ESX5.1 hosts? But how to do this? With the vCenter Update Manager I cannot add neither the .vib nor the .zip (unrecognized file).
Thanks for your support....
Re: vSphere VAAI plugin
I would like to know too...Qnap support isn't very good about documenting things.
Thank you, Tom
Thank you, Tom
Does anyone has managed to install this plugin?
QNAP TS-219P
2 * SAMSUNG HD103SJ 1To HDD (RAID1)
1 * Seagate ST3320620AS 320GB HDD (eSATA)
FW QTS 4.0.2
TwonkyMedia 5.1.6, Download Station, Surveillance Station, MySQL, Windows File Sharing
FTP, SSH, Jumbo Frame (9K), iSCSI (ESXi)
Netgear switch gigabit Ethernet, DEVOLO AV+ (x4), Belkin F5D7132 AP Wifi 802.11g
DLINK DSM-510 (MediaServer), Shuttle Barebone XP PRO 64 (Gigabit) , Dell Insipiron XP PRO
FW QTS 4.0.2
VMware gave me this info:
Existing ESXi installation using esxcli and async driver VIB file You can install async drivers on an existing ESXi host from an async driver VIB file. The VIB file is copied to the ESXi host using the datastore browser, and installed using esxcli in the ESXi shell.
Note: This requires remote ESXi network connectivity using the vSphere Client.
To install the async drivers:
1. Extract the contents of the async driver zip file.
2. Identify the offline-bundle.zip file(s).
3. Extract the contents of the offline-bundle.zip file(s).
4. Identify the async-driver.vib file(s).
5. Log into the ESXi host using the vSphere Client with administrator privileges, such as root.
6. Using the Datastore Browser, upload the async-driver.vib file(s) to an ESXi host’s datastore.
7. Enter the host into maintenance mode.
8. Log in as root to the ESXi console through SSH or iLO/DRAC.
9. Run this command to install drivers from the VIB file (this requires an absolute path):
esxcli software vib install –v /path/async-driver.vib
For example:
esxcli software vib install –v /vmfs/volumes/datastore/async-driver.vib
10. Reboot the ESXi host.
11. Exit maintenance mode.
Please refer the below mentioned KB article for more information:-
http://kb.vmware.com/kb/2005205
There's also a way to do it via update manager but I got an error (unrecognized file) and asked Qnap support about it, I may have a response before December. I also told VMware about the error and asked for more info on how to use a local shared repository...
HTH Tom
For example:
HTH Tom
I had emailed Qnap...I was asked for the version number of THEIR plugin!!
Had I known tech support was so awful I would never have bought a Qnap, sigh...
Nothing works as it's supposed to...iSCSI doesn't work at all, VMware said it was because something, I can't remember what, was not being read...
I've asked QNAP support, too .. and got an email answer:
"Sehr geehrter Herr Braun,
anbei ein Link:
https://my.vmware.com/web/vmware/downloads
Mit freundlichen Grüßen..."
WTF???
anbei ein Link:
WTF???
Qnap support doesn't know beans
Do the procedure I gave from VMware
To put the zip file into local storage, use the datastore browser
Then ssh into the host, do cd vmfs/volumes/your_local_storage
Do a ls and you should see your Qnap plugin there
Then type unzip Q followed by hitting the tab key
Then you should see the zip and vib files
Then you can do the above procedure to install the vib
If you are using VMware ESXI 5.5 - you need to add --no-sig-check to the end as well e.g.
esxcli software vib install -v /vmfs/volumes/datastore1/QNAP_QNPNasPlugin_1.0.vib --no-sig-check
Otherwise it fails with no valid signature/license found.
Qnap tech support told me this vib requires firmware 4.0.5 installed to the Qnap, this firmware is not yet released...
Go figure!!
Meanwhile Thank you for the 5.5 tip!!
Go figure!!
This has worked for me as well... However, even though the vib is now listed and showing as installed, the module is not loading. Even after rebooting my ESXi 5.5 host a couple times.MikeSpragg wrote:If you are using VMware ESXI 5.5 - you need to add --no-sig-check to the end as well e.g.
Mike, were you able to actually get ESXi to load the module after the vib was installed and the host rebooted? Were there perhaps some additional steps required?
-= TS-459 Pro II =-
Hi
same with me: module is not listed after installation and reboot. What is missing here?
Thx
Thx
UPDATE: Over the last few weeks I had 2/4 of my 2TB drives fail. When the first one failed, I replaced the single drive and the RAID rebuild started but wouldn't finish and the load of my TS-459 Pro II spiked well over 100 and the Web UI became unusable... in an effort to get things rebuilt and my device usable again, I replaced all 4 of my 26 month old 2TB Seagate drives with 3TB WD Red drives AND updated the firmware to the beta 4.1.0 .. Raid6 build went very well and completed overnight.
Why am I posting this here? Because, once the build was complete, I created a new 2.5 TB iSCSI target and told my ESXi 5.5 server to rescan datastores. I then added the target and confirmed that "hardware acceleration" is now showing as "Supported" !!
-= TS-459 Pro II =-
- teracow
- Easy as a breeze
I (like many others) have left this forum due to the incompetence of QNAP staff.
I have now completed deletion of all my posts (how-to's, images, hand-written instructions, on-the-fly user manuals, etc..). These are now gone.
I am not interested in assisting QNAP any further when they won't assist me. Anyone unlucky enough to have dealt with Adong Lin (QNAP Systems Inc.) or the blundering incompetence of the 'live chat' specialist AJ Lee will know what I mean. Adong doesn't understand the first thing about basic computer interoperability and AJ disconnects you from live chat when he doesn't want to deal with your problem.
I will not support QNAP any further. Far from it - I will now be recommending a competitor's hardware instead. I'm done.
Seagate Barracuda LP: ST2000DL003
The drive is listed here: http://wiki.qnap.com/wiki/Compatible/In ... .5#Seagate but then now listed here as "not recommended": http://www.qnap.com/useng/index.php?sn=4085&lang=en-us
I had 4 of these in RAID5 configuration and they worked quite nicely for the first 25 months, then during month 26 (Nov 2013) the failures started happening. My NAS was running 24X7 since I got it over 2 years ago for use in my home lab with vSphere.
-= TS-459 Pro II =-
- teracow
- Easy as a breeze
