Hi guys,
I tried to set up QNAP 859 as a secondary domain controller to existing Windows domain... but I don't see "Domain Controller" option.
I'm using 4.1.3 Build.
Print - screen attached.
Please help
Greetings,
Aleksander.
No Domain Controller option...
Re: No Domain Controller option...
I have the same problem. I use a TS-869U-RP with os 4.1.3. Its no Domain Controller option. I Want to Use my TS-869U-RP as primary Domain Controller.
Please help.
Daniel
Please help.
Daniel
- schumaku
Afraid, the TS-x59 Series (and earlier, like TS-x63, TS-509/809) don't come with SAMBA 4 - so no Domain Controller functionality available.
Check the product specs or http://docs.qnap.com/ FMI.
PS. There was an option to force these NAS models to SAMBA4, however this might be no longer possible - because of the tar ball is no longer up2date or available.
Thaks for answer, i've checked the Product specs for my NAS. The Chapter 5.6 show me the configuration option for Domain Contoller but my OS don´t show me these options. I feel lost.
Daniel
Daniel
- schumaku
Nope, different...tecpc wrote:I have the same problem.
NAS configured on earlier firmware versions are not automatically convert to SAMBA 4 - QNAPtecpc wrote:I use a TS-869U-RP with os 4.1.3. Its no Domain Controller option. I Want to Use my TS-869U-RP as primary Domain Controller. ... The Chapter 5.6 show me the configuration option for Domain Contoller but my OS don´t show me these options.
Of course - trouble is QNAP decided not to make SAMBA 4 available by default on NAS migrated from earlier firmware versions and SAMBA 3.x - so no SMB 3.0 or Domain COntroller options.
/etc/init.d/samba4.sh reinstall_samba keep
Now SMB 3.0 protocol should be available - can't tell you right now if a reboot is required or just a re-login get the smb3enable:[~] # /etc/init.d/samba4.sh reinstall_samba keep
reinstall samba!!!!
Shutting down SMB services: smbd nmbd.
Shutting down winbindd services: winbindd.
install /mnt/HDA_ROOT/update_pkg/samba4.tgz
Restarting SMB services:
Version 3.6.24 -> Version 4.0.16
locks path was set to /share/MD0_DATA/.locks
Starting winbindd services:Starting SMB services:.
done.
[~] # smb3enable
For the Domain Controller controls to appear ... I don't know if the process above is sufficient, if there is a need to logout and re-login again, or a reboot is required.
Please nobody try this in the TS-x59 (or similar older NAS where the samba4.sh and samba4.tgz is available) - it does refuse to keep SAMBA 4.
Regards,
-Kurt.
Great it works!
Thank you.
Regards
Daniel
Thank you.
Regards
Daniel
- pwilson
You need to enable Domain Security before the option becomes available. Check out the Domain Controller section of the SMB version of the QNAP Turbo NAS User Manual.tecpc wrote:Thaks for answer, i've checked the Product specs for my NAS. The Chapter 5.6 show me the configuration option for Domain Contoller but my OS don´t show me these options. I feel lost.
This feature is NOT supported on models that use the "Home" version of the Firmware, and therefore the "Home" version of the QNAP Turbo NAS User Manual as already explained by schumaku.
Patrick M. Wilson
Victoria, BC Canada
It is very unfortunate and quite frustrating. I bought my TS-559 Pro+ a few years ago and it was listed in the SMB category. It now seems to have been silently "demoted" to the Home category?
I did manage to upgrade SMB to v2.0 using the following command:
But SMB v3.0 is still unsupported.
What frustrates me even more is that I just bought a TS-231 (for another purpose) that has much lower capacity (CPU, RAM, disks) than my TS-559 Pro+ and it has SAMBA 4. I conclude that the limitation is not because of the hardware capacity but rather a deliberate choice of QNAP not to include SAMBA 4 in the firmware intended for older models in order to force people to buy newer units to get the latest features.
I understand that QNAP needs to make money somehow. And providing free full upgrades forever is not one of them. However, I would not mind paying something to "unlock" the latest features instead of having to buy a new unit to replace one that still works perfectly.
If someone finds a way to get a TS-X59 working with SAMBA 4, please let me know.
[/etc/init.d] # ./smb2_protocol.sh status
smbd (samba daemon) Version 3.6.25
smbd (samba daemon) is running.
max protocol SMB 1.0 enabled.
[/etc/init.d] # ./smb2_protocol.sh enable 2
max protocol SMB 2.0 ... enabled.
Starting winbindd services: winbindd.
max protocol SMB 2.0 enabled.
[/etc/init.d] # ./smb2_protocol.sh enable 3
max protocol SMB 3.0 ... not supported.
