I have a NAS TS431 version 4.1.2 with Music Station installed, as soon as I launch the app it comes up with session timeout, what have I done wrong in the set-up?
Ed
Music Station - Session Timeout
Re: Music Station - Session Timeout
Same problem with Music Station version 4.6.4. Connecting to the Qnap dlna server shows only empty results. Another thing is that on my device the nas shows up 2 times ?
solved:
My fault, i forgot to put a checkmark on music in the multimedia management.
solved:
charliego - I wish it were that simple, I've got ticks in Multimedia management, I've copied files to every folder ie QSync, root of multimedia, etc No music. Photos work fine. Ed
- pwilson
eddiex wrote:I have a NAS TS431 version 4.1.2 with Music Station installed, as soon as I launch the app it comes up with session timeout, what have I done wrong in the set-up?
Ed
- Is Multimedia Management enabled?
- Has Multimedia Management finished "scanning/indexing/thumbnailing" all your Media?
- Have you added the locations of your Music to the Multimedia Management folder scan?
Patrick M. Wilson
Victoria, BC Canada
Well I now have music, although the unit said it had scanned everything, I got it to rebuild the library index (took it nearly 24 hours for 600 songs) but now it has found them.
So I suppose that is a success but not the most impressive app I've seen
Thanks for you help
Ed
Thanks for you help
Ed
Hi pwilson! Your posted informations are very useful to me then i like to say thank you for your posting,
thank you very much sir. Keep in touch with us.
