I've just transferred all my photo/video library in my qnap and I'm starting to use photo station. I've correctly added the source folder and photo station finds:
12034 photos
If I use Picasa (installed on mmy win PC) to see the very same lib, it finds:
12659 photos
Why the numbers of the same folder are different?
ts420 with 2 hdd wd in raid 1 (2TB each)
firmware 4.1.3
single ethernet port
Photostation: number of files
firmware 4.2.2
firmware 4.2.2
Re: Photostation: number of files
I've discovered that some jpg files are not find by photostation but are find by picasa. Now I have to understand why photostation do not see those files. Please, give me a suggestion...
firmware 4.2.2
firmware 4.2.2
- Been there, done that
Unfortunately PhotoStation has limited setting options therefore it is difficult to say how it works, if there is some filter, dupe check or, on the contrary it's a problem of the database created by Picasa...
Qnap TS-253Pro 16Gb RAM - Single Storage Pool: 2 WRed 4TB (RAID 1)
Qnap TS-453A 16Gb RAM - Single Storage Pool: 4 WRed 4TB (RAID 5)
I do not think that the database created by Picasa can cause a problem in photostation: now i'm testing with just a folder containing just 4 JPG and one of them is seen by photostation and the others not. Another strange think is that I'm able to open them from the mediaviewer in filestation.
It seems that those jpg have an attribute that makes them incompatible with photostation....
firmware 4.2.2
firmware 4.2.2
- Easy as a breeze
are they small files with dimension less then 400x400?
media library would skip the small files in my testing.
Yes they are small files. Now I understand. Thanks
firmware 4.2.2
firmware 4.2.2
