Unable to mount md0 after reboot
Discussion on remote replication.
M4rc3L
Post by M4rc3L »
I'm having trouble mounting my raid 5 array. The problem is that QNAP tells me the raid array is 5 disks and raid1, because this was set once in the config. Though the raid array is 8 disks in raid5. According to mdadm the raid array is clean and running (doing so manually):
] # cat /proc/mdstat
md0 : active raid5 sda3[0] sdf3[7] sdg3[6] sdh3[5] sdd3[4] sde3[3] sdc3[2] sdb3[1]
13663619200 blocks level 5, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
Also e2fsck shows me the filesystem is clean and no errors, als I can mount it manually. But after reboot it goes wrong again.
Now I noticed storage_boot_init 2 creates /etc/storage.conf, which has data set wrong (5 disks). How does QNAP generate this storage.conf and how can I change it?
Hope you have a answer for me!
sl1000
Experience counts
Re: Unable to mount md0 after reboot
Post by sl1000 »
what does /etc/config/mdadm.conf tell you
Try searching the perfect online manual, forum or the Wiki for answers before posting
### Retired developer ###
M4rc3L
Post by M4rc3L »
This is the output:
[~] # cat /etc/config/mdadm.conf
ARRAY /dev/md9 level=raid1 num-devices=8 UUID=593ea513:c94a0843:b99f8beb:7929179a
ARRAY /dev/sda4 level=raid1 num-devices=8 UUID=7d4c921d:4e081a1e:f297a436:3555d01b
ARRAY /dev/md8 level=raid1 num-devices=2 spares=6 UUID=c6d42637:3225f36a:2fa0d027:4f43cec5
ARRAY /dev/md0 level=raid5 num-devices=8 UUID=a800170a:412a7332:80621c94:e0a4c168
Which is correct for /dev/md0. Though I don't know what /dev/md9 /dev/sda4 /dev/md8 really mean, I guess it's qnap related.
schumaku
Contact:
Post by schumaku »
Very obscure - in my opinion, it should never look like that on a QNAP NAS! What firmware version is in place? To much played aorund with mdadm while attemting to re-assemble the RAID I'd say... Don't remember if there was a period, where QNAP made us of the UUID format - unlikley however.
This is a typical one (from a four bay x86 unit - extend to the number of drives you previously had in your RAID):
ARRAY /dev/md0 devices=/dev/sda3,/dev/sdb3,/dev/sdc3,/dev/sdd3
Return to “Remote Replication/ Disaster Recovery”
