hey Qnap users
i have a issu.
and it looks like it happens after the new update, i am on 4.0.5 and i have a TS412
well its hard to describe bud i going to do my ferry best
when i am at my pc and i try to type in de Bar of windows explorer my "nas name" like so "//NASC90544" <- that is how i normally get in my NAS files
windows tells me this
Titel : network ERROR
Description: windows cannot acces \\NASC90544
check the spelling of the name. otherwise, there might be a problem whit your network. to try to identify and resolve network problems, click diagnose.
well this is BoelSh**T because when i type in my ip of the nas witch is static (192.168.2.1) and when i type in that it can get in. ferry strange HU ?
what i try so fare
i have try to open the nas at a different PC
NOTE: i can see an access the ohter pc('s) in my network by the "network name" only the "nasc90544" gives me this problem.
i try to change the network name of my nas from "NASC90544" to "QNAS"
NOTE: i see Qnas in my network list but get the same network error. when i go to the IP i can access it
i have try to reboot and even RESET my Router. but non of that helps
I have try reboot the NAS several times ( 3 times or so )
non of this helps
what i don't try
i don't try to go back one update (downgrade)
i don't try to reset te NAS. because i don't wanna loos my data.
so pleas can some one tells me what is wrong.
and are there people ho face the same error
THX
Starpc
network name not found
- pwilson
Re: network name not found
When you're asking a question, please include the followingstarpc wrote:hey Qnap users
i have a issu.
what i try so fare
non of this helps
what i don't try
THX
Starpc
Patrick M. Wilson
Victoria, BC Canada
- starpc
Your Operating System you are using to access your NAS. windows 7/8.1
NAS model qnap ts412
Firmware revision 4.0.2
Network Setup (ie Single Port or Port Trunking) one network port the first one
If Port Trunking is present please specify (choose correct one): port forwarder in router are 81 / and 8080
Balance-rr (Round-Robin) what ??
Active Backup no
Balance XOR ???
static IP 192.168.2.1
Broadcast ??
IEEE 802.3ad (Dynamic Link Aggregation) ??
Balance-tlb (Adaptive Transmit Load Balancing) ??
Balance-alb (Adaptive Load Balancing) ??
If Disk related please also specify:
Drive Configuration: SingleDrive's 4 intern 2 via e-sata
For each drive please provide: Drive 1 SAMSUNG HD322HJ 1AC0/ Drive 2 SAMSUNG HD322HJ 1AC0 /Drive 3 WDC WD 2500KS-00MJB0 02.0 /Drive 4 SAMSUNG HD322HJ 1AC0 /Drive 5 SAMSUNG HD322HJ 1AC0 /drive 6 SAMSUNG HD322HJ 1AC0
Active Backup no
Balance XOR ???
Broadcast ??
- pwilson
You've established that your NAS is at: 192.168.2.1starpc wrote:Your Operating System you are using to access your NAS. windows 7/8.1
Network Setup (ie Single Port or Port Trunking) : Single Port
What Make/Model of Router are you using?
What is the internal IP address of your Router?
Please access the command line of your Windows box and execute the following commands:
ipconfig /all
nslookup NASC90544
Please install PuTTY on your Windows box. (PuTTY is a freely available multi-platform SSH client).
(Secure Shell has been around for almost 20 years now, but Microsoft still does not provide a client with Windows )
Using PuTTY please login to your NAS via SSH, (login as "admin") and execute the following commands:
touch /tmp/dnsreport
chmod +x /tmp/dnsreport
cat <<EOF >>/tmp/dnsreport
#!/bin/sh
# DNS Report by Patrick Wilson
# see: http://forum.qnap.com/viewtopic.php?f=185&t=82260#p366188
echo "*********************"
echo "** QNAP DNS Report **"
echo " "
echo "NAS Model: $(getsysinfo model)"
echo "Firmware: $(getcfg system version) Build $(getcfg system 'Build
Number')"
echo " "
echo "Default Gateway Device: $(getcfg network 'Default GW Device')"
echo " "
ifconfig $(getcfg network 'Default GW Device') | grep -v HWaddr
echo " "
echo -n "DNS Nameserver(s):"
cat /etc/resolv.conf | grep nameserver | cut -d' ' -f2
echo " "
echo "Check DNS for qnap.com:"
echo "nslookup qnap.com"
nslookup qnap.com
echo "Check DNS for qnap.com with $(route -n | grep UG | grep 0.0.0.0 | awk '{print $2}') as DNS Server"
echo "nslookup qnap.com $(route -n | grep UG | grep 0.0.0.0 | awk '{print $2}')"
echo " "
echo "Check DNS for $(getcfg system "Server Name"):"
echo "nslookup $(getcfg system "Server Name")"
echo "Check DNS for $(getcfg system "Server Name") with $(route -n | grep UG | grep 0.0.0.0 | awk '{print $2}') as DNS Server"
echo "nslookup $(getcfg system "Server Name") $(route -n | grep UG | grep 0.0.0.0 | awk '{print $2}')"
echo " "
echo "Routing Table:"
route -n
echo " "
echo "DNSReport completed on $(date +'%Y-%m-%d %T') ($0)"
EOF
sleep 2
clear
/tmp/dnsreport
echo "Done."
Please cut&paste the output of the resulting "DNS Report" back to this message thread.
Patrick M. Wilson
Victoria, BC Canada
- starpc
well first i think. i found out what is goin on.
i thing its in the Microsoft networking setting in the nas. i try to enable and disable it but doing noting. and last week i take my nas to a friend of my and the same error. so in my opinion its not in my network its in the TS-412
o and change my NAS name to "qnap" so its "QNAP" now bud that is not working two
the model is a arcadyan vgv7519 custom FIRMW by my ADSL provider KPN. so not mutch to change besides the port forwarding/wifi settings/lan settings ( like static IP's)
its of 192.168.2.1 to 192.168.2.254
192.168.2.254 - Router main adres (user interface)
ipconfig /all
and nslookup Qnap
putty output
Be four i forget to say
thank for try to help me Patrick M. Wilson <- LIKE
well my router is of my ADSL provider.pwilson wrote: What Make/Model of Router are you using?
My DHCP range ?pwilson wrote: What is the internal IP address of your Router?
ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : acer
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Wireless LAN adapter Local Area Connection* 12:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Hosted Network
Physical Address. . . . . . . . . : 00-22-FA-1B-64-FD
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 A
Physical Address. . . . . . . . . : 00-22-FA-1B-64-FC
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Atheros AR8121/AR8113/AR8
et Controller
Physical Address. . . . . . . . . : 00-A0-D1-AC-3D-F2
Link-local IPv6 Address . . . . . : fe80::50d6:5bae:8f4c:cbfe
IPv4 Address. . . . . . . . . . . : 192.168.2.8(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, January 29, 20
Lease Expires . . . . . . . . . . : Friday, January 31, 2014
Default Gateway . . . . . . . . . : 192.168.2.254
DHCP Server . . . . . . . . . . . : 192.168.2.254
DHCPv6 IAID . . . . . . . . . . . : 50372817
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-4C-5F-3B-0
DNS Servers . . . . . . . . . . . : 192.168.2.254
195.121.1.34
195.121.1.66
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.home:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Server: router.home
Address: 192.168.2.254
*** router.home can't find Qnap: Non-existent domain
NAS Model: TS-412
Firmware: 4.0.5 Build
Default Gateway Device: eth0
inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:35620324 errors:0 dropped:0 overruns:0 frame:0
TX packets:30410293 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:3588625048 (3.3 GiB) TX bytes:3585948941 (3.3 GiB)
Interrupt:15
DNS Nameserver(s):192.168.2.254
195.121.1.34
195.121.1.66
nslookup qnap.com
Server: router.home
Address: 211.78.87.229
Check DNS for qnap.com with 192.168.2.254 as DNS Server
nslookup qnap.com 192.168.2.254
Server: router.home
Check DNS for qnas:
nslookup qnas
Server: router.home
Address: 192.168.2.1
Check DNS for qnas with 192.168.2.254 as DNS Server
nslookup qnas 192.168.2.254
Server: router.home
Routing Table:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.2.2 0.0.0.0 255.255.255.255 UH 0 0 0 tun0
192.168.2.0 192.168.2.2 255.255.255.0 UG 0 0 0 tun0
192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 192.168.2.254 0.0.0.0 UG 0 0 0 eth0
DNSReport completed on 2014-01-30 22:19:03 (-sh)
NAS Model: TS-412
RX packets:35620389 errors:0 dropped:0 overruns:0 frame:0
TX packets:30410362 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3588653351 (3.3 GiB) TX bytes:3585956478 (3.3 GiB)
Interrupt:15
195.121.1.34
195.121.1.66
nslookup qnap.com
Server: router.home
Server: router.home
Check DNS for qnas:
nslookup qnas
Server: router.home
Server: router.home
Routing Table:
DNSReport completed on 2014-01-30 22:21:22 (-sh)
- pwilson
Disable OpenVPN, or switch it back to using 10.8.0.1-10.8.0.254.starpc wrote:well first i think. i found out what is goin on.
ipconfig /alland nslookup QnapCode: Select all
Windows IP Configuration Host Name . . . . . . . . . . . . : acer Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : home Wireless LAN adapter Local Area Connection* 12: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Hosted Network Physical Address. . . . . . . . . : 00-22-FA-1B-64-FD DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : home Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 A Physical Address. . . . . . . . . : 00-22-FA-1B-64-FC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet: Connection-specific DNS Suffix . : home Description . . . . . . . . . . . : Atheros AR8121/AR8113/AR8 et Controller Physical Address. . . . . . . . . : 00-A0-D1-AC-3D-F2 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::50d6:5bae:8f4c:cbfe IPv4 Address. . . . . . . . . . . : 192.168.2.8(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Wednesday, January 29, 20 Lease Expires . . . . . . . . . . : Friday, January 31, 2014 Default Gateway . . . . . . . . . : 192.168.2.254 DHCP Server . . . . . . . . . . . : 192.168.2.254 DHCPv6 IAID . . . . . . . . . . . : 50372817 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-4C-5F-3B-0 DNS Servers . . . . . . . . . . . : 192.168.2.254 195.121.1.34 195.121.1.66 NetBIOS over Tcpip. . . . . . . . : Enabled Tunnel adapter isatap.home: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : home Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
putty outputCode: Select all
Server: router.home Address: 192.168.2.254 *** router.home can't find Qnap: Non-existent domain
Be four i forget to sayCode: Select all
********************* ** QNAP DNS Report ** ********************* NAS Model: TS-412 Firmware: 4.0.5 Build Default Gateway Device: eth0 inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0 UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1 RX packets:35620324 errors:0 dropped:0 overruns:0 frame:0 TX packets:30410293 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:532 RX bytes:3588625048 (3.3 GiB) TX bytes:3585948941 (3.3 GiB) Interrupt:15 DNS Nameserver(s):192.168.2.254 195.121.1.34 195.121.1.66 Check DNS for qnap.com: nslookup qnap.com Server: router.home Address: 192.168.2.254 Name: qnap.com Address: 211.78.87.229 Check DNS for qnap.com with 192.168.2.254 as DNS Server nslookup qnap.com 192.168.2.254 Server: router.home Address: 192.168.2.254 Name: qnap.com Address: 211.78.87.229 Check DNS for qnas: nslookup qnas Server: router.home Address: 192.168.2.254 Name: qnas Address: 192.168.2.1 Check DNS for qnas with 192.168.2.254 as DNS Server nslookup qnas 192.168.2.254 Server: router.home Address: 192.168.2.254 Name: qnas Address: 192.168.2.1 Routing Table: Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.2 0.0.0.0 255.255.255.255 UH 0 0 0 tun0 192.168.2.0 192.168.2.2 255.255.255.0 UG 0 0 0 tun0 192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo 0.0.0.0 192.168.2.254 0.0.0.0 UG 0 0 0 eth0 DNSReport completed on 2014-01-30 22:19:03 (-sh) ********************* ** QNAP DNS Report ** ********************* NAS Model: TS-412 Firmware: 4.0.5 Build Default Gateway Device: eth0 inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0 UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1 RX packets:35620389 errors:0 dropped:0 overruns:0 frame:0 TX packets:30410362 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:532 RX bytes:3588653351 (3.3 GiB) TX bytes:3585956478 (3.3 GiB) Interrupt:15 DNS Nameserver(s):192.168.2.254 195.121.1.34 195.121.1.66 Check DNS for qnap.com: nslookup qnap.com Server: router.home Address: 192.168.2.254 Name: qnap.com Address: 211.78.87.229 Check DNS for qnap.com with 192.168.2.254 as DNS Server nslookup qnap.com 192.168.2.254 Server: router.home Address: 192.168.2.254 Name: qnap.com Address: 211.78.87.229 Check DNS for qnas: nslookup qnas Server: router.home Address: 192.168.2.254 Name: qnas Address: 192.168.2.1 Check DNS for qnas with 192.168.2.254 as DNS Server nslookup qnas 192.168.2.254 Server: router.home Address: 192.168.2.254 Name: qnas Address: 192.168.2.1 Routing Table: Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.2 0.0.0.0 255.255.255.255 UH 0 0 0 tun0 192.168.2.0 192.168.2.2 255.255.255.0 UG 0 0 0 tun0 192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo 0.0.0.0 192.168.2.254 0.0.0.0 UG 0 0 0 eth0 DNSReport completed on 2014-01-30 22:21:22 (-sh)
(This is a known Bug).
Patrick M. Wilson
Victoria, BC Canada
- doktornotor
Well, quite honestly defining your VPN so that it overlaps the LAN range and wondering why it breaks is not exactly a bug. It must NEVER be the same as your LAN! And while at it, the "defaults" in the GUI should be randomized, otherwise you soon get things borked when having the same subnet in use on both VPN sites.
I'm gone from this forum till QNAP stop wasting volunteers' time. Get help from QNAP helpdesk instead.
Warning: offensive signature and materials damaging QNAP reputation follow:
QNAP's FW security issues
QNAP's hardware compatibility list madness
QNAP's new logo competition
Dear QNAP, kindly fire your clueless incompetent forum "admin" And while at it, don't forget the webmaster!
- starpc
I AM flabbergasted>
in other words the network name works again
never thocht aboud that +10 to you
