email at startup
email at startup
is there a way to send a notification right after the start of my Qnap 639 ?? I (and some users) start the Qnap over WOL and I want a email that the device is ready. Is there a way to do this ?? If not I think it is a nice feature for office Admins Like me, because every time someone Wakes the Qnap I have an Email.
- pwilson
Re: email at startup
Easy to do already. Simply create your "autorun.sh" file on your NAS. See QNAPedia article: Running Your Own Application at Startup; (Use the MTD method, despite what the Wiki says).hallohome wrote:is there a way to send a notification right after the start of my Qnap 639 ?? I (and some users) start the Qnap over WOL and I want a email that the device is ready. Is there a way to do this ?? If not I think it is a nice feature for office Admins Like me, because every time someone Wakes the Qnap I have an Email.
Assuming that your SSMTP Server on the NAS is properly configured, and you can successfully send test notification e-mails. The following script would do it for you.
(Note you will need to modify the SendTo, SendFrom, and (possibly Subject) variables at the top of the script
/share/homes/admin/bin/wol-notify.sh
#!/bin/sh
# wol-notify.sh - aka /share/homes/admin/bin/wol-notify.sh
# This script e-mails the designated recipient upon NAS Startup.
# See QNAP Forum article: http://forum.qnap.com/viewtopic.php?f=24&t=99093
SendTo="me@somewhere.com"
SendFrom="TS-639@XXXXXX.myqnapcloud.com"
Subject="$(/bin/hostname) started at: $(/bin/date)"
rm -f /tmp/wol-notify.email
touch /tmp/wol-notify.email
echo "From: ${SendFrom}" >>/tmp/wol-notify.email
echo "To: ${SendTo}" >>/tmp/wol-notify.email
echo "Subject: ${Subject}" >>/tmp/wol-notify.email
echo " " >>/tmp/wol-notify.email
cat <<EOF >>/tmp/nasreport
echo "NAS Model: $(getsysinfo model)"
echo "Firmware: $(getcfg system version) Build $(getcfg system 'Build Number')"
echo "System Name: $(/bin/hostname)"
echo "Workgroup: $(getcfg system workgroup)"
echo "Base Directory: $(dirname \$(getcfg -f /etc/config/smb.conf Public path))"
echo "NAS IP address: $(ifconfig $(getcfg network 'Default GW Device') | grep addr: | awk '{ print $2 }' | cut -d: -f2)"
echo " "
EOF
cat /tmp/wol-notify.email | /usr/sbin/sendmail -t
echo "Done."
#done
chmod +x /share/homes/admin/bin/wol-notify.sh
Test this script from the command line, and modify it to your own specifications. When you get the desired output (ie an e-mail from the NAS) successfully, you can add this to your "autorun.sh" file so that it "auto-runs" at every Startup.
#!/bin/sh
# NAS Autorun.sh file
touch /tmp/autorun.ran
#done
#!/bin/sh
# Create the "autorun.sh" file on my TS-639 Pro
mount /dev/sdx6 /tmp/config
touch /tmp/config/autorun.sh
chmod +x /tmp/config/autorun.sh
cat << EOF >> /tmp/config/autorun.sh
#!/bin/sh
#done
EOF
umount /tmp/config
#done
Patrick M. Wilson
Victoria, BC Canada
