For an IT admin or someone running a small business it would be invaluable to have the ability to schedule a simple report showing the utilisation of your hard disks.
Resource Monitor already has a great looking window called "Disk Usage" we just need the ability to e-mail this in HTML based on a schedule.
The e-mail would just list the raid or virtual disk and then show Total, used and free disk space.
For qnap units that have very high traffic on a daily basis this would be a great addition.
Regards, Mike
Resource report
- pwilson
Re: Resource report
Assuming that your SSMTP Server is properly configured, and you can successfully send test notification e-mails. The following script would do it for you.themuscle wrote:For an IT admin or someone running a small business it would be invaluable to have the ability to schedule a simple report showing the utilisation of your hard disks.
Regards, Mike
(Note you will need to modify the SendTo, SendFrom, and (possibly Subject) variables at the top of the script
#!/bin/sh
# nasnotify.sh - aka /share/homes/admin/bin/nasnotify.sh
# This script e-mails a report on the NAS / Drive Status to the designated recipient
# See QNAP Forum article: http://forum.qnap.com/viewtopic.php?f=24&t=99093
SendTo="me@somewhere.com"
SendFrom="TS-459@XXXXXX.myqnapcloud.com"
Subject="Resource Report from $(/bin/hostname)"
rm -f /tmp/nasreport.email
touch /tmp/nasreport.email
echo "From: ${SendFrom}" >>/tmp/nasreport.email
echo "To: ${SendTo}" >>/tmp/nasreport.email
echo "Subject: ${Subject}" >>/tmp/nasreport.email
echo " " >>/tmp/nasreport.email
chmod +x /tmp/nasreport
cat <<EOF >>/tmp/nasreport
#!/bin/sh
# NAS Report by Patrick Wilson
# see: http://forum.qnap.com/viewtopic.php?f=185&t=82260#p366188
echo "*********************"
echo "** QNAP NAS Report **"
echo " "
echo "NAS Model: \$(getsysinfo model)"
echo "Firmware: \$(getcfg system version) Build \$(getcfg system 'Build Number')"
echo "System Name: \$(/bin/hostname)"
echo "Workgroup: \$(getcfg system workgroup)"
echo "Base Directory: \$(dirname \$(getcfg -f /etc/config/smb.conf Public path))"
echo "NAS IP address: \$(ifconfig \$(getcfg network 'Default GW Device') | grep addr: | awk '{ print \$2 }' | cut -d: -f2)"
echo " "
echo "Default Gateway Device: \$(getcfg network 'Default GW Device')"
echo " "
ifconfig \$(getcfg network 'Default GW Device') | grep -v HWaddr
echo " "
echo -n "DNS Nameserver(s):"
cat /etc/resolv.conf | grep nameserver | cut -d' ' -f2
echo " "
echo " "
echo "HDD Information:"
echo " "
if [ -x /sbin/hdparm ]; then
for i in {a..d}; do echo -n /dev/sd\$i ; hdparm -i /dev/sd\$i | grep "Model"; done
else
echo " /sbin/hdparm is not present"
fi
echo " "
echo "Disk Space:"
echo " "
df -h | grep -v qpkg | grep -v grep
echo " "
echo "Mount Status:"
echo " "
mount | grep -v qpkg
echo " "
echo "RAID Status:"
echo " "
cat /proc/mdstat
echo " "
#echo "QNAP Media Scanner / Transcoder processes running: "
#echo " "
#/bin/ps | grep medialibrary | grep -v grep
#echo " "
#echo -n "MediaLibrary Configuration file: "
#ls -alF /etc/config/medialibrary.conf
#echo " "
#echo "/etc/config/medialibrary.conf:"
#cat /etc/config/medialibrary.conf
echo " "
echo "Memory Information:"
echo " "
cat /proc/meminfo | grep Mem
echo " "
echo "NASReport completed on \$(date +'%Y-%m-%d %T') ($0)"
EOF
/tmp/nasreport >>/tmp/nasreport.email
cat /tmp/nasreport.email | sendmail -t
echo "Done."
#done
This isn't pretty, but it will get the job done without any MIME encoding, or HTML bloat. It's a simple text report, surely text is good enough for the e-mail message too to get the job done. Tested here. This script successfully delivered my NASReport output to my e-mail box. Simply save this script to somewhere on your NAS that will survive a reboot. (I created it at /share/homes/admin/bin/nasnotify.sh here)
If you save this script to the same location and make it executable, you can run if from the command line as often as you want.
chmod +x /share/homes/admin/bin/nasnotify.sh
You can also make it run daily by adding it to the NAS Crontab file. If you wanted to run it at 3am every Sunday you can do this with the following commands:
echo "0 3 * * 0 /share/homes/admin/bin/nasnotify.sh" >>/etc/config/crontab
#load Crontab changes...
crontab /etc/config/crontab
#restart Cron daemon to pickup the new item
/etc/init.d/crond.sh restart
#done
Patrick M. Wilson
Victoria, BC Canada
Re: Resource report
This is great, I will give it a try over the weekend.
Thanks for the reply.
Regards, Michael
Regards, Michael
Re: Resource report
Thanks for this Patrick.
I realized what a mess crontab is in after installing notestation.
Re: Resource report
This does not work for me. I receive "SENDMAIL: 550 5.6.0 Invalid header found (see RFC2822 section 3.6) Done. I can send a test email from the GUI control panel just fine so it's definitely in the script.
- schumaku
Re: Resource report
Unkless you have added some Mess-DOS CR/LF line terminators to the script ...michael14094 wrote:This does not work for me. I receive "SENDMAIL: 550 5.6.0 Invalid header found (see RFC2822 section 3.6) Done. I can send a test email from the GUI control panel just fine so it's definitely in the script.
The key is that most SMTP handlers require a valid "From:" address - instead of the suggested ...
...use your e-mail address configured for SMTP submission on the NAS.
It works:
Return-Path: <kurt.<<snip>>>
Received: from TVS-473 (<<snip>>. [<<snip>>])
by smtp.gmail.com with SMTPSA id <<snip>>.2.2016.11.19.12.44.21
for <kurt.<<snip>>>
(version=TLS1_2 cipher=AES128-SHA bits=128/128);
Sat, 19 Nov 2016 12:44:22 -0800 (PST)
Message-ID: <<<snip>>@mx.google.com>
Received: by TVS-473 (sSMTP sendmail emulation); Sat, 19 Nov 2016 21:41:23 +0100
Date: Sat, 19 Nov 2016 21:41:23 +0100
To: kurt.<<snip>>
Subject: Resource Report from TVS-473
NAS Model: TVS-473
Firmware: 4.3.0 Build 20161107
System Name: TVS-473
Re: Resource report
I have done that, of course. I am using the exact same "from" and "to" addresses that I have setup in the gui. I can send test emails from the gui with no problem. I am using the smtp server from my isp which I use as a smtp relay server with all of my other devices perfectly fine. There is something in this script that the smtp server does not like.
- schumaku
Re: Resource report
Strongly doubt...michael14094 wrote:There is something in this script that the smtp server does not like.
Change the sendmail (ssmtp) options from -t to -v -t near to the end:
old:
cat /tmp/nasreport.email | sendmail -v -t
..and now run the script again. Post the output (remove any sensitive AUTH data like usernames, paswords, or XOAUTH2 code. I'm glad to have an eye on your output.
Note: As per RFC2822 section 3.6 only two fields (plus the receiver address as a "To" obviously) are mandatory - marked bold in this example:
[<-] 220 smtp.gmail.com ESMTP g10sm19946697wjw.18 - gsmtp
[->] HELO TVS-473
[<-] 250 smtp.gmail.com at your service
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 400 100 294 100 106 580 209 --:--:-- --:--:-- --:--:-- 601
[->] AUTH XOAUTH2 <<SNIP>>==
[<-] 235 2.7.0 Accepted
[->] MAIL FROM:<kurt.<<SNIP>>>
[<-] 250 2.1.0 OK g10sm19946697wjw.18 - gsmtp
[->] RCPT TO:<kurt.<<SNIP>>>
[<-] 250 2.1.5 OK g10sm19946697wjw.18 - gsmtp
[->] DATA
[<-] 354 Go ahead g10sm19946697wjw.18 - gsmtp
[->] Received: by TVS-473 (sSMTP sendmail emulation); Sun, 20 Nov 2016 16:51:47 +0100
[->] Date: Sun, 20 Nov 2016 16:51:47 +0100
[->] From: kurt.<<SNIP>>
[->] To: kurt.<<SNIP>>
[->] Subject: Resource Report from TVS-473
[->] ** QNAP NAS Report **
[->] NAS Model: TVS-473
[->] Firmware: 4.3.0 Build 20161107
[->] System Name: TVS-473
