SMART is all fine.
2new drives showed same issue in same bay, until i pulled the first drive and put in 2nd bay. Btw, this is the first time I noticed drives are magnetic on the top. perhaps only those WD4000FYYZ drives are MAGNETIC! wow!
When I put in the first drive, it kinda attached to the 2nd bay slot. Weird sh*t.
[~] # dmesg
[ 68.148957] created bitmap (1 pages) for device md256
[ 68.154156] md256: bitmap initialized from disk: read 1 pages, set 9 of 9 bit s
[ 68.168616] md256: detected capacity change from 0 to 542834688
[ 68.174611] RAID1 conf printout:
[ 68.174625] --- wd:2 rd:2
[ 68.174637] disk 0, wo:0, o:1, dev:sdd2
[ 68.174647] disk 1, wo:0, o:1, dev:sdc2
[ 68.174657] RAID1 conf printout:
[ 68.174679] --- wd:2 rd:2
[ 68.174689] disk 0, wo:0, o:1, dev:sdd2
[ 68.174699] disk 1, wo:0, o:1, dev:sdc2
[ 68.174765] md: resync of RAID array md256
[ 68.178885] md: minimum _guaranteed_ speed: 5000 KB/sec/disk.
[ 68.184729] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
[ 68.194120] md: Resyncing started: md256
[ 68.198057] md: using 128k window, over a total of 530112k.
[ 68.227474] md256: unknown partition table
[ 68.307341] Adding 530108k swap on /dev/md256. Priority:-1 extents:1 across: 530108k
[ 68.578594] md: md1 stopped.
[ 68.589909] md: bind<sdc3>
[ 68.592818] md: bind<sdb3>
[ 68.595738] md: bind<sda3>
[ 68.598630] md: bind<sdd3>
[ 68.602408] md/raid:md1: device sdd3 operational as raid disk 0
[ 68.608347] md/raid:md1: device sda3 operational as raid disk 3
[ 68.614272] md/raid:md1: device sdb3 operational as raid disk 2
[ 68.620193] md/raid:md1: device sdc3 operational as raid disk 1
[ 68.633125] md/raid:md1: allocated 69504kB
[ 68.637296] md/raid:md1: raid level 6 active with 4 out of 4 devices, algorit hm 2
[ 68.644782] RAID conf printout:
[ 68.644792] --- level:6 rd:4 wd:4
[ 68.644803] disk 0, o:1, dev:sdd3
[ 68.644814] disk 1, o:1, dev:sdc3
[ 68.644824] disk 2, o:1, dev:sdb3
[ 68.644834] disk 3, o:1, dev:sda3
[ 68.644885] md1: detected capacity change from 0 to 7981186285568
[ 68.660540] md1: unknown partition table
[ 68.801368] md13: unknown partition table
[ 69.973485] dm_create -1
[ 69.976042] mapped_device minor=0
[ 69.979802] dm_table_add_target start linear, start=0, len=41943040, param=9: 1 2048, type=18446744071588674400...
[ 69.990088] dm-linear: ti->max_io_len = 0
[ 69.994126] bio: create slab <bio-1> at 1
[ 70.019286] dm_create -1
[ 70.021844] mapped_device minor=1
[ 70.025543] dm_table_add_target start linear, start=0, len=33161216, param=9: 1 15554693120, type=18446744071588674400...
[ 70.036442] dm-linear: ti->max_io_len = 0
[ 70.040725] dm_create -1
[ 70.043276] mapped_device minor=2
[ 70.046978] dm_table_add_target start linear, start=0, len=15512748032, param =9:1 41945088, type=18446744071588674400...
[ 70.057870] dm-linear: ti->max_io_len = 0
[ 70.062387] dm_create -1
[ 70.064941] mapped_device minor=3
[ 70.068611] dm_table_add_target start thin-pool, start=0, len=15512748032, pa ram=253:1 253:2 2048 0 1 skip_block_zeroing, type=18446744072100075200...
[ 70.085482] device-mapper: thin metadata: __create_persistent_data_objects: b lock manger get correctly
[ 70.250870] device-mapper: thin: Data device (dm-2) discard unsupported: Disa bling discard passdown.
[ 70.260143] dm_create -1
[ 70.262699] mapped_device minor=4
[ 70.266506] dm_table_add_target start linear, start=0, len=15512748032, param =253:3 0, type=18446744071588674400...
[ 70.276957] dm-linear: ti->max_io_len = 0
[ 70.281906] dm_table_add_target start thin-pool, start=0, len=15512748032, pa ram=253:1 253:2 2048 0 1 skip_block_zeroing, type=18446744072100075200...
[ 70.295515] dm_create -1
[ 70.298065] mapped_device minor=5
[ 70.301785] dm_table_add_target start thick, start=0, len=15508848640, param= 253:3 1, type=18446744072100074944...
[ 70.367708] bio: create slab <bio-2> at 2
[ 70.371900] device-mapper: thin: Data device (dm-2) discard unsupported: Disa bling discard passdown.
[ 71.501876] dm_create -1
[ 71.504427] mapped_device minor=0
[ 71.508121] dm_table_add_target start flashcache, start=0, len=15508848640, p aram=CG0 /dev/mapper/vg1-lv1 cachedev1, type=18446744072100148000...
[ 73.318923] EXT4-fs (dm-0): Mount option "noacl" will be removed by 3.5
[ 73.318923] Contact linux-ext4@vger.kernel.org if you think we should keep it .
[ 73.318923]
[ 74.154825] ext4_init_reserve_inode_table0: dm-0, 59162
[ 74.160062] ext4_init_reserve_inode_table2: dm-0, 59162, 0, 0, 4096
[ 74.166354] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,noacl
[ 88.583623] kjournald starting. Commit interval 5 seconds
[ 88.642829] EXT3-fs (md13): using internal journal
[ 88.647631] EXT3-fs (md13): mounted filesystem with ordered data mode
[ 95.337635] cryptodev: driver 0.9 loaded.
[ 95.353136] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
[ 95.359554] iTCO_wdt: Found a Baytrail SoC TCO device (Version=4, TCOBASE=0x0 460)
[ 95.369330] iTCO_wdt: initialized. heartbeat=120 sec (nowayout=0)
[ 95.392329] fnotify: Load file notify kernel module.
[ 95.397756] fnotify: Launch the fnotify thread: 18446612133602078784
[ 95.415566] iTCO_wdt: Timeout value (heartbeat) is set to 120
[ 96.444143] usbcore: registered new interface driver snd-usb-audio
[ 96.452445] usbcore: registered new interface driver snd-usb-caiaq
[ 96.467557] usbcore: registered new interface driver uvcvideo
[ 96.473334] USB Video Class driver (1.1.1)
[ 96.538723] 8021q: 802.1Q VLAN Support v1.8
[ 126.356634] 8021q: adding VLAN 0 to HW filter on device eth0
[ 126.615063] 8021q: adding VLAN 0 to HW filter on device eth1
[ 126.873416] 8021q: adding VLAN 0 to HW filter on device eth2
[ 127.123604] 8021q: adding VLAN 0 to HW filter on device eth3
[ 129.494547] igb: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/ TX
[ 133.482836] md: md256: resync done.
[ 133.486374] md: Resyncing done: md256
[ 133.517362] RAID1 conf printout:
[ 133.517380] --- wd:2 rd:2
[ 133.517395] disk 0, wo:0, o:1, dev:sdd2
[ 133.517407] disk 1, wo:0, o:1, dev:sdc2
[ 133.533965] RAID1 conf printout:
[ 133.533976] --- wd:2 rd:2
[ 133.533987] disk 0, wo:0, o:1, dev:sdd2
[ 133.533998] disk 1, wo:0, o:1, dev:sdc2
[ 133.534007] RAID1 conf printout:
[ 133.534025] --- wd:2 rd:2
[ 133.534037] disk 0, wo:0, o:1, dev:sdd2
[ 133.534049] disk 1, wo:0, o:1, dev:sdc2
[ 166.737515] igb: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/ TX
[ 188.088801] warning: `proftpd' uses 32-bit capabilities (legacy support in us e)
[ 207.516819] rule type=2, num=0
[ 207.588600] Loading iSCSI transport class v2.0-870.
[ 207.600681] iscsi: registered transport (tcp)
[ 212.708120] Set msys_nodify as 31743
[ 217.558220] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery d irectory
[ 217.566086] NFSD: starting 90-second grace period (net ffffffff8196b040)
[ 220.635586] [fintek_proc_write] cir enable
[ 220.639766] fintek_cir: fintek-cir: Dump CIR logical device registers:
[ 220.646308] fintek_cir: * CR CIR BASE ADDR: 0xffff
[ 220.651193] fintek_cir: * CR CIR IRQ NUM: 0xff
[ 220.655906] fintek_cir: fintek-cir: Dump CIR registers:
[ 220.661148] fintek_cir: * STATUS: 0xff
[ 220.665349] fintek_cir: * CONTROL: 0xff
[ 220.669541] fintek_cir: * RX_DATA: 0xff
[ 220.673732] fintek_cir: * TX_CONTROL: 0xff
[ 220.677926] fintek_cir: * TX_DATA: 0xff
[ 5354.449961] tun: Universal TUN/TAP device driver, 1.6
[ 5354.455025] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 5354.476637] NET: Registered protocol family 10
[ 5354.481705] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5354.487929] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 5354.493922] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
[ 5354.510814] Bridge firewalling registered
