RAID Group 1 recovery failed.
Hi to all,
we have a problem since this morning on our QNAP TS-870U-RP (RAID-Type: 5).
We had a disconnected disk.
After a new insert of the same disk, the rebuild process started.
The next hint within the system log is "Mount the file system read-only" and "Rebuilding skipped with RAID Group 1"
I replaced Drive5 and tried to rebuild RAID Group. Result: "RAID Group 1 recovery failed:"
Please see also attached logfile: Could anyone help us please?
Thank you very much.
Re: RAID Group 1 recovery failed.
I have the some problem, How did you do to fix it?
more info than that please ...cquinonez wrote:I have the some problem, How did you do to fix it?
Hello.
We have a NAS with 8 disk, we have created a raid 5 group with 7 disks and 1 disk as spare.
The spare disk failed this weekend, and today the disk number 3 of the raid group also failed.
In that moment, the volume mounted over these raid group, was going as read only state.
Then, I replaced the disk number 3, and the system recognized the disk as good, but the raid group is still inactive.
I have tried to reactive it, but always returns me the message: "raid group 1 recovery failed"
Please help me, I need to access to my information.
Regards.
NAS Model:TS-EC879U-RP
Firmware version: 4.2.2 Build 20160812
Regards.
are you certain that the 8th disk was not a member disk ?
because if a hot/coldspare fails and after that a normal disk, that should be a degraded RAID not a read only one
your scenario sounds more like another failed drive during rebuild
- MrVideo
Yes, it most certain does. Using RAID5 with that many discs was just asking for trouble.
QTS MANUALS
Entware
Entware
Yes, I'm sure of that. The 8th disk was an spare disk, and when this disk failed the raid group continued operating normally.dolbyman wrote:are you certain that the 8th disk was not a member disk ?
I'm attaching to this message some images from the admin console, when you can see the raid group, the syslog and the message of the inactive raid group.
I need to know if exists something to do for resolve this trouble.
Thanks.
- OneCD
This won't fix your problem, but may provide more information about your current configuration.cquinonez wrote:I need to know if exists something to do for resolve this trouble.
You'll need to SSH / PuTTY into your NAS as the 'admin' user to access the command line.
Then run the following command:
cat /proc/mdstat
Thanks, here is the output of the command...OneCD wrote:This won't fix your problem, but may provide more information about your current configuration.cquinonez wrote:I need to know if exists something to do for resolve this trouble.
Then run the following command:... and post the output back here.Code: Select all
cat /proc/mdstat
This solve the problem...thanks
[~] # df -h
Filesystem Size Used Available Use% Mounted on
none 250.0M 183.1M 66.9M 73% /
devtmpfs 1.9G 8.0k 1.9G 0% /dev
tmpfs 64.0M 284.0k 63.7M 0% /tmp
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
/dev/md9 509.5M 135.6M 373.9M 27% /mnt/HDA_ROOT
cgroup_root 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/md13 371.0M 281.7M 89.3M 76% /mnt/ext
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
[~] # md_checker
Welcome to MD superblock checker (v1.4) - have a nice day~
Scanning system...
HAL firmware detected!
Scanning Enclosure 0...
RAID metadata found!
UUID: 2e2c2d0d:254e12fb:60fd48fc:c0a5cd8f
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Creation Time: Jun 23 18:25:36 2015
Status: OFFLINE
Disk | Device | # | Status | Last Update Time | Events | Array State
1 /dev/sdc3 0 Rebuild Jan 9 13:07:50 2017 1333 AAAAAAA
2 /dev/sdd3 1 Active Jan 9 13:07:50 2017 1333 AAAAAAA
-------------- 2 Missing -------------------------------------------
4 /dev/sda3 3 Active Jan 9 13:07:50 2017 1333 AAAAAAA
5 /dev/sde3 4 Active Jan 9 13:07:50 2017 1333 AAAAAAA
6 /dev/sdf3 5 Active Jan 9 13:07:50 2017 1333 AAAAAAA
7 /dev/sdg3 6 Active Jan 9 13:07:50 2017 1333 AAAAAAA
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
3 /dev/sdb3 2 Active Jan 9 13:07:50 2017 1333 AAAAAAA
[~] # mdadm -A /dev/md1 /dev/sd[dbaefg]3
mdadm: failed to get exclusive lock on mapfile - continue anyway...
mdadm: /dev/md1 assembled from 6 drives - need all 7 to start it (use --run to i nsist).
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
-------------- 0 Missing -------------------------------------------
[~] # mdadm -A /dev/md1 /dev/sd[dbaefg]3 --run
mdadm: /dev/md1 has been started with 6 drives (out of 7).
[~] # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [multi path]
md1 : active raid5 sdd3[1] sdg3[6] sdf3[5] sde3[4] sda3[3] sdb3[2]
11661357696 blocks super 1.0 level 5, 64k chunk, algorithm 2 [7/6] [_UUUUU U]
md256 : active raid1 sdb2[2] sdg2[6](S) sdf2[5](S) sde2[4](S) sda2[3](S) sdd2[1]
530112 blocks super 1.0 [2/2] [UU]
bitmap: 0/1 pages [0KB], 65536KB chunk
md13 : active raid1 sdb4[2] sdg4[6] sdf4[5] sde4[4] sda4[3] sdd4[1]
458880 blocks [8/6] [_UUUUUU_]
bitmap: 48/57 pages [192KB], 4KB chunk
md9 : active raid1 sdb1[2] sdg1[6] sdf1[5] sde1[4] sda1[3] sdd1[1]
530048 blocks [8/6] [_UUUUUU_]
bitmap: 49/65 pages [196KB], 4KB chunk
unused devices: <none>
[~] # /etc/init.d/init_lvm.sh
Changing old config name...
mv: unable to rename `/etc/config/qdrbd.conf': No such file or directory
Reinitialing...
Detect disk(8, 0)...
dev_count ++ = 0Detect disk(8, 16)...
dev_count ++ = 1Detect disk(8, 48)...
dev_count ++ = 2Detect disk(8, 64)...
dev_count ++ = 3Detect disk(8, 80)...
dev_count ++ = 4Detect disk(8, 96)...
dev_count ++ = 5Detect disk(8, 112)...
ignore non-root enclosure disk(8, 112).
sys_startup_p2:got called count = -1
Command failed
Done
[~] # df -h
none 250.0M 183.4M 66.6M 73% /
tmpfs 64.0M 316.0k 63.7M 0% /tmp
/dev/md9 509.5M 135.6M 373.8M 27% /mnt/HDA_ROOT
/dev/mapper/cachedev1 156.6T 7.9T 148.6T 5% /share/CACHEDEV1_DATA
[~] # mount
none on /new_root type tmpfs (rw,mode=0755,size=256000k)
/proc on /proc type proc (rw)
devpts on /dev/pts type devpts (rw)
sysfs on /sys type sysfs (rw)
tmpfs on /tmp type tmpfs (rw,size=64M)
tmpfs on /dev/shm type tmpfs (rw)
tmpfs on /share type tmpfs (rw,size=16M)
/dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered)
cgroup_root on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/cgroup/memory type cgroup (rw,memory)
/dev/md13 on /mnt/ext type ext3 (rw,data=ordered)
tmpfs on /mnt/rf/nd type tmpfs (rw,size=1m)
none on /sys/kernel/config type configfs (rw)
/dev/mapper/cachedev1 on /share/CACHEDEV1_DATA type ext4 (rw,usrjquota=aquota.us er,jqfmt=vfsv0,user_xattr,data=ordered,delalloc,acl)
[~] # umount /share/CACHEDEV1_DATA/
umount: /share/CACHEDEV1_DATA: device is busy
[~] # df -h
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
Reinitialing...
Command failed
Done
[~] # df -h
[~] # mount
- MrVideo
It would have been nice if you would have enclosed all of your report within a code block, like this (as a minimum):
Or you could have enclosed each command run in its own code block. It just makes it all easier to read.
But, what has really caught my eye is that you are running 7 drives under RAID5. Five, or more, drives should be using RAID6.
[~] # df -h
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
[~] # md_checker
Scanning system...
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Status: OFFLINE
Reinitialing...
Command failed
Done
[~] # df -h
[~] # mount
QTS MANUALS
Entware
Entware
