Has anybody experienced a really high performance hit when using SSD cache (with the option to cache all transfers including sequential ones)? Since I upgraded QTS to 4.1.3, i have had to disable SSD caching for my volumes since transfers were putting the NAS load to 80+. This exact same setup was working like a charm with 4.1.2
My device is a TS853 Pro, with 7x4TB WD Reds in a RAID6 configuration and one SSD for cache. NFS is the most commonly used protocol, although CIFS and iSCSI are used as well. RAM is also not an issue
total used free shared buffers
Mem: 16338832 16204976 133856 0 36352
Swap: 530108 0 530108
Total: 16868940 16204976 663964
