Does anyone know whether Logwatch can be installed on our NASs (without creating any problems) and if so how to install it?
Thank you
How can I install Logwatch on my TS-212?
- pwilson
Re: How can I install Logwatch on my TS-212?
What is LogWatch? Hard to help without basic information provided.No Expert wrote:Hi,
Thank you
LogWatch is a pretty generic name, perhaps you could provide a URL that tells us something about it.
Patrick M. Wilson
Victoria, BC Canada
Apologies,
I thought it was a widely used term.
I was referring to this:
http://linux.die.net/man/8/logwatch
http://sourceforge.net/projects/logwatch/files/
- pwilson
This version of Logwatch seems to be Perl based, so it can probably be modified to work on your NAS, even a Marvel/ARM based one such as your TS-212. The logging on the NAS is minimal, as /var/log lives in a RAMDisk.No Expert wrote:Apologies,
QNAP NAS devices do not use RPM files, but it seems to provide a standard .tgz version too, which you can probably install fairly easily. You will need Perl installed on the NAS for sure for this to have a hope of working, but Perl is available in the App Center.
Patrick M. Wilson
Victoria, BC Canada
Thank you.
I will give it a go.
Did you get it working? Hoping to install on my 451.
