My questions are:
I see in another thread that the advice is to HOT SWAP the faulty drive for a new one. Is that the best/only option I have?
Is this something that can be fixed?
Thanks in advance for the help!
Basic info below:
Operating System: Mac OS X 10.10.4
NAS model: TS-419P+
Firmware: 4.1.4 Build 20150522
Network: Single port
Drive Configuration: RAID5
Number of drives: 4
Drive Manufacturer: Samsung
Drive Model: HD204UI
Drive Firmware revision (if available): 1AQ10001
(All 4 drives are the same model)
According to the web interface the RAW VALUE of Current_Pending_Sector is "1".
Here's a dump of the SMART info from the problematic drive:
[~] # get_hd_smartinfo -d 2
001 Raw_Read_Error_Rate 1 100 100 051 OK
002 Throughput_Performance 18425 055 049 000 OK
003 Spin_Up_Time 17264 044 039 025 OK
004 Start_Stop_Count 14715 086 086 000 OK
005 Reallocated_Sector_Ct 0 252 252 010 OK
007 Seek_Error_Rate 0 252 252 051 OK
008 Seek_Time_Performance 0 252 252 015 OK
009 Power_On_Hours 24966 100 100 000 OK
010 Spin_Retry_Count 0 252 252 051 OK
011 Calibration_Retry_Count 0 252 252 000 OK
012 Power_Cycle_Count 11 100 100 000 OK
181 Program_Fail_Count 10979 100 100 000 OK
191 G-Sense_Error_Rate 13 100 100 000 OK
192 Power-Off_Retract_Count 0 252 252 000 OK
194 Temperature_Celsius 36 064 050 000 OK
195 Hardware_ECC_Recovered 0 100 100 000 OK
196 Reallocated_Event_Count 0 252 252 000 OK
197 Current_Pending_Sector 1 100 100 000 ABNORMAL
198 Offline_Uncorrectable 0 252 252 000 OK
199 UDMA_CRC_Error_Count 0 200 200 000 OK
200 Multi_Zone_Error_Rate 124 100 100 000 OK
223 Load_Retry_Count 0 252 252 000 OK
225 Load_Cycle_Count 14715 099 099 000 OK
