My QT-412 boots, enables the interface and is accessible via ssh but not (at least not in reasonable time) through the web interface.
The trouble started when I tried to create a RAID1 with two external drives using normal mdadm commands, I would assume that something in the automatic RAID config got broke by that. (I know, my bad, but who knew?)
After that, the webui showed the RAID status as "failed" although it was still active and I could access it through nfs, /proc/mdstat was showing a perfectly healthy RAIDset, too.
When I rebooted, the system did come up with a dhcp ip address and I had to re-configure the interface through qfinder.
After that, I could login with admin and my ssh key, so that data was preserved, but I found the system in the state as shown below minus /dev/md0
As you can see, I can activate my md0 just fine, even through a mdadm --assemble --scan, so md seems to be happy with the supberblocks.
My drives:
/sbin/hdparm -i /dev/sd[a-d] 2>/dev/null |grep Model
Model=WDC WD30EFRX-68EUZN0 , FwRev=82.00A82, SerialNo= WD-WCC4N1CZP0D7
Model=WDC WD30EFRX-68EUZN0 , FwRev=82.00A82, SerialNo= WD-WCC4N7VXZN79
Model=WDC WD30EFRX-68EUZN0 , FwRev=80.00A80, SerialNo= WD-WCC4NRD7DV7P
Model=WDC WD30EFRX-68EUZN0 , FwRev=82.00A82, SerialNo= WD-WMC4N0F1CXD5
cat /proc/mdstat
Personalities : [raid1] [linear] [raid0] [raid10] [raid6] [raid5] [raid4]
md0 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
8786092608 blocks super 1.0 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
bitmap: 0/11 pages [0KB], 131072KB chunk
md13 : active raid1 sdb4[0] sdd4[3] sdc4[2] sda4[1]
458880 blocks [4/4] [UUUU]
bitmap: 0/57 pages [0KB], 4KB chunk
md9 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]
530048 blocks [4/4] [UUUU]
bitmap: 0/65 pages [0KB], 4KB chunk
My Superblocks:
mdadm --examine /dev/sda3
/dev/sda3:
Magic : a92b4efc
Version : 1.0
Feature Map : 0x1
Array UUID : d4b34e44:00da9f33:712188f4:d2ef62ca
Creation Time : Sun May 10 08:58:28 2015
Raid Level : raid5
Raid Devices : 4
Used Dev Size : 5857395112 (2793.02 GiB 2998.99 GB)
Array Size : 17572185216 (8379.07 GiB 8996.96 GB)
Used Size : 5857395072 (2793.02 GiB 2998.99 GB)
Super Offset : 5857395368 sectors
State : clean
Device UUID : 9f1c7674:8e8ac1f1:2b2a4122:ec2d55c6
Internal Bitmap : 2 sectors from superblock
Update Time : Sat Oct 31 14:17:22 2015
Checksum : f0fef5b2 - correct
Events : 9
Layout : left-symmetric
Chunk Size : 64K
Array Slot : 0 (0, 1, 2, 3, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed)
Array State : Uuuu 380 failed
mdadm --examine /dev/sdb3
/dev/sdb3:
Magic : a92b4efc
Version : 1.0
Feature Map : 0x1
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : be20431e:831f7db0:b35dd759:781f541a
Update Time : Sat Oct 31 14:17:27 2015
Checksum : e51cb3df - correct
Events : 9
Chunk Size : 64K
Array Slot : 1 (0, 1, 2, 3, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed)
Array State : uUuu 380 failed
mdadm --examine /dev/sdc3
/dev/sdc3:
Magic : a92b4efc
Version : 1.0
Feature Map : 0x1
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 921c0251:c24ca13b:30b9f050:5a21bc34
Update Time : Sat Oct 31 14:17:57 2015
Checksum : b4813a70 - correct
Events : 9
Chunk Size : 64K
Array Slot : 2 (0, 1, 2, 3, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed)
Array State : uuUu 380 failed
mdadm --examine /dev/sdd3
/dev/sdd3:
Magic : a92b4efc
Version : 1.0
Feature Map : 0x1
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : 32539d79:99d15121:f1976784:f0de07f8
Update Time : Sat Oct 31 14:18:17 2015
Checksum : b98f9254 - correct
Events : 9
Chunk Size : 64K
Array Slot : 3 (0, 1, 2, 3, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed)
Array State : uuuU 380 failed
For reasons unknown,
getcfg system version
yields nothing. Not a thing, but I've recently upgraded to 4.2
mdadm --examine --scan
ARRAY /dev/md9 level=raid1 num-devices=4 UUID=82234069:44f6464a:543cfa98:bdf63dbc
ARRAY /dev/md/4 level=raid1 metadata=1.0 num-devices=2 UUID=a2b283af:1c3f61a5:bbede3ff:29e9e0af name=4
ARRAY /dev/md/0 level=raid5 metadata=1.0 num-devices=4 UUID=d4b34e44:00da9f33:712188f4:d2ef62ca name=0
ARRAY /dev/md13 level=raid1 num-devices=4 UUID=7ef8bc9b:8c8c662b:80b39f00:a2dda617
cat /etc/config/raidtab
raiddev /dev/md0
raid-level 5
nr-raid-disks 4
nr-spare-disks 0
chunk-size 4
persistent-superblock 1
device /dev/sda3
raid-disk 0
device /dev/sdb3
raid-disk 1
device /dev/sdc3
raid-disk 2
device /dev/sdd3
raid-disk 3
[VOLUME 1]
device name = /dev/md0
raid level = 5
raid disks = 1,2,3,4
spare raid disks =
status = 0
record_time = Fri May 8 17:01:25 2015
filesystem = 104
[Global]
Available Disk = 4
[~] # dmesg
EXT3-fs (md9): mounted filesystem with writeback data mode
[ 30.211518] md: md13 stopped.
[ 30.571732] md: bind<sda4>
[ 30.572045] md: bind<sdc4>
[ 30.572320] md: bind<sdd4>
[ 30.572589] md: bind<sdb4>
[ 30.576076] md/raid1:md13: active with 4 out of 4 mirrors
[ 30.576315] created bitmap (57 pages) for device md13
[ 30.583960] md13: bitmap initialized from disk: read 4/4 pages, set 0 of 114720 bits
[ 30.640547] md13: detected capacity change from 0 to 469893120
[ 30.668358] md13: unknown partition table
[ 32.216266] kjournald starting. Commit interval 5 seconds
[ 32.350891] EXT3-fs (md9): using internal journal
[ 32.350923] EXT3-fs (md9): mounted filesystem with writeback data mode
[ 33.113997] kjournald starting. Commit interval 5 seconds
[ 33.190925] EXT3-fs (md9): using internal journal
[ 33.190958] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 37.950841] kjournald starting. Commit interval 5 seconds
[ 38.010776] EXT3-fs (md13): using internal journal
[ 38.011130] EXT3-fs (md13): recovery complete
[ 38.011157] EXT3-fs (md13): mounted filesystem with writeback data mode
[ 99.355282] fuse init (API version 7.18)
[ 99.609118] NET: Registered protocol family 5
[ 99.910860] md: linear personality registered for level -1
[ 99.956722] md: raid0 personality registered for level 0
[ 99.985540] md: raid10 personality registered for level 10
[ 100.025233] xor: measuring software checksum speed
[ 100.070360] arm4regs : 1067.200 MB/sec
[ 100.120355] 8regs : 759.200 MB/sec
[ 100.170353] 32regs : 904.800 MB/sec
[ 100.170374] xor: using function: arm4regs (1067.200 MB/sec)
[ 100.630501] raid6: int32x1 87 MB/s
[ 100.800453] raid6: int32x2 120 MB/s
[ 100.970367] raid6: int32x4 132 MB/s
[ 101.140579] raid6: int32x8 119 MB/s
[ 101.140600] raid6: using algorithm int32x4 (132 MB/s)
[ 101.140620] raid6: using intx1 recovery algorithm
[ 101.164391] async_tx: api initialized (async)
[ 101.262466] md: raid6 personality registered for level 6
[ 101.262502] md: raid5 personality registered for level 5
[ 101.262522] md: raid4 personality registered for level 4
[ 101.584439] device-mapper: ioctl: 4.22.1-ioctl (2012-06-01) initialised: dm-devel@redhat.com
[ 101.847607] MV-CESA:Fallback driver 'hmac(sha1)' could not be loaded!
[ 101.847652] alg: hash: Failed to load transform for mv-hmac-sha1: -2
[ 101.899627] cryptodev: driver 0.9 loaded.
[ 102.030709] usbcore: registered new interface driver usbhid
[ 102.030747] usbhid: USB HID core driver
[ 102.083424] usbcore: registered new interface driver usblp
[ 102.112224] sysinfo: Module loaded.
[ 102.241752] jnl: driver (lke_9.2.0 QNAP, LBD=ON) loaded at bf1f6000
[ 102.282946] ufsd: module license 'Commercial product' taints kernel.
[ 102.282986] Disabling lock debugging due to kernel taint
[ 102.310541] ufsd: driver (lke_9.2.0 QNAP, build_host("BuildServer35"), acl, ioctl, bdi, sd2(0), fua, bz, rsrc) loaded at bf204000
[ 102.310554] NTFS support included
[ 102.310558] Hfs+/HfsJ support included
[ 102.310562] optimized: speed
[ 102.310566] Build_for__QNAP_TS-120_k3.4.6_2014-11-19_lke_9.2.0_r245986_b9
[ 102.310572]
[ 102.488564] RPC: Registered named UNIX socket transport module.
[ 102.488604] RPC: Registered udp transport module.
[ 102.488623] RPC: Registered tcp transport module.
[ 102.488641] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 102.681605] NFS: Registering the id_resolver key type
[ 102.858331] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 103.162455] fnotify: Load file notify kernel module.
[ 103.222021] lib80211: common routines for IEEE802.11 drivers
[ 103.222144] lib80211_crypt: registered algorithm 'NULL'
[ 103.395191] cfg80211: Calling CRDA to update world regulatory domain
[ 105.030696] usbcore: registered new interface driver snd-usb-audio
[ 105.056340] usbcore: registered new interface driver snd-usb-caiaq
[ 105.148070] Linux video capture interface: v2.00
[ 105.317500] uvcvideo: Unable to create debugfs directory
[ 105.325753] usbcore: registered new interface driver uvcvideo
[ 105.325791] USB Video Class driver (1.1.1)
[ 106.524408] eth0: link down
[ 106.524454] eth0: started
[ 106.551529] eth1: started
[ 106.734683] eth0: stopped
[ 106.740704] eth0: mac address changed
[ 106.767299] eth0: started
[ 106.797466] eth1: stopped
[ 106.803473] eth1: mac address changed
[ 106.830000] eth1: started
[ 109.632942] eth0: link up, full duplex, speed 1 Gbps
[ 119.141147] EXT2-fs (mtdblock5): warning: mounting unchecked fs, running e2fsck is recommended
[ 122.332927] kjournald starting. Commit interval 5 seconds
[ 122.370858] EXT3-fs (md9): using internal journal
[ 122.370889] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 125.915009] active port 0 :139
[ 125.915043] active port 1 :445
[ 125.915058] active port 2 :20
[ 130.447859] EXT2-fs (mtdblock5): warning: mounting unchecked fs, running e2fsck is recommended
[ 133.308539] Unable to find swap-space signature
[ 140.769140] Unable to find swap-space signature
[ 147.598801] Unable to find swap-space signature
[ 153.798697] Unable to find swap-space signature
[ 157.199328] md: md0 stopped.
[ 158.269406] md: md0 stopped.
[ 160.929244] md: md0 stopped.
[ 166.279267] md: md0 stopped.
[ 169.789560] md: md0 stopped.
[ 184.415222] eth0: stopped
[ 184.421946] eth1: stopped
[ 186.563646] eth0: link down
[ 186.563691] eth0: started
[ 186.700877] eth1: started
[ 189.764528] eth0: link up, full duplex, speed 1 Gbps
[ 209.017714] eth0: stopped
[ 209.044286] eth0: link down
[ 209.044322] eth0: started
[ 209.119479] eth1: stopped
[ 209.142917] eth1: started
[ 211.795606] eth0: link up, full duplex, speed 1 Gbps
[ 236.934595] active port 0 :139
[ 236.934629] active port 1 :445
[ 236.934644] active port 2 :20
[ 249.290230] Initiate iscsi target log successfully.
[ 249.482598] iscsi_log_rcv_msg: get log pid = 5596.
[ 254.583961] EXT2-fs (mtdblock5): warning: mounting unchecked fs, running e2fsck is recommended
[ 258.323254] warning: process `pic_raw' used the deprecated sysctl system call with 8.1.2.
[ 260.256451] rule type=2, num=0
[ 260.450688] MAC:00:08:9B:CF:60:1C
[ 260.451360] page 3, reg 18 = 4a85
[ 260.452637] WOL enable
[ 260.463762] MAC:00:08:9B:CF:60:1D
[ 260.464405] page 3, reg 18 = 4a85
[ 260.465682] WOL enable
[ 263.793880] Loading iSCSI transport class v2.0-871.
[ 264.319684] iscsi: registered transport (tcp)
[ 265.448890] iscsid (6325): /proc/6325/oom_adj is deprecated, please use /proc/6325/oom_score_adj instead.
[ 323.788853] iscsi target log cleanup successfully.
[ 727.830678] md: md0 stopped.
[ 727.979983] md: bind<sdb3>
[ 727.980247] md: bind<sdc3>
[ 727.981529] md: bind<sdd3>
[ 727.981784] md: bind<sda3>
[ 727.985482] md/raid:md0: device sda3 operational as raid disk 0
[ 727.985520] md/raid:md0: device sdd3 operational as raid disk 3
[ 727.985543] md/raid:md0: device sdc3 operational as raid disk 2
[ 727.985566] md/raid:md0: device sdb3 operational as raid disk 1
[ 728.101788] md/raid:md0: allocated 67840kB
[ 728.103132] md/raid:md0: raid level 5 active with 4 out of 4 devices, algorithm 2
[ 728.103169] RAID conf printout:
[ 728.103177] --- level:5 rd:4 wd:4
[ 728.103187] disk 0, o:1, dev:sda3
[ 728.103195] disk 1, o:1, dev:sdb3
[ 728.103203] disk 2, o:1, dev:sdc3
[ 728.103211] disk 3, o:1, dev:sdd3
[ 728.116663] created bitmap (11 pages) for device md0
[ 728.118285] md0: bitmap initialized from disk: read 1/1 pages, set 0 of 22345 bits
[ 728.170611] md0: detected capacity change from 0 to 8996958830592
[ 966.318906] md0: unknown partition table
so - to me, it's either something with the superblock themselves or with the way they are being interpreted.
Any ideas?
kind regards
pj
