I am using a TVS-871 with FW 4.2 and 4 volumes over 1 storage pool.
Today i renamed a volume (alias) and forgot to move one share inside that volume.
This share, all folders and files seem to be lost...since i didn't delete them shouldn't they still exist on the NAS file system?
Regards,
Rui Mota
Volume rename alias and shares
- MrVideo
Re: Volume rename alias and shares
It would help to know exactly what you did.
QTS MANUALS
Entware
Entware
Basically i renamed one volume on the NAS control Panel.
This volume had 1 share configured with several folders and files.
I tried to find these files with SSH client, because de volume renamed had an allocation size that didn't match with the occupation size, but couldn't find any files at all.
- MrVideo
I have no idea what you did actually does. If you had done it via a SSH login command line, then maybe.
If you tried finding a file by the "find" command, searching from "/" and came up empty, then I suspect that what you did deleted everything. For example:
Then you will have to restore everything from your backups.
find / -iname \*.jpg
QTS MANUALS
Entware
Entware
