My setup is 4 2tb hdd in a raid 5 on a TS-451 NAS.
I would like to use cache acceleration option to get better performance. I main use this to run plex server and storage purposes. Since I have multiple friends using my plex content, NAS performs slow. I am thinking adding this might improve the performance of the NAS.
Can I connect the Samsung external SSD to Usb 3.0 port and setup cache acceleration?
if yes, do I need to re-setup the volumes? which RAID should use?
Thanks in advance.
-Urv
SSD Cache Acceleration on TS-451
- Don
Re: SSD Cache Acceleration on TS-451
No. Cache has to be on an internal slot. Not sure your model supports cache.
How did you determine that the disk is your bottleneck?
For the TS x51 series some references say it is supported and some do not mention it.
I suspect this is a case of documentation not being updated consistently which is why forums are useful.
This page says it is supported.
http://docs.qnap.com/nas/4.1/SMB/en/ind ... ration.htm
Model SSD slots Trays Supported
TS-x51 All No limit
TS-x51 All No limit
In my TVS-871 I had 2 ssd's in slots 0 & 1, I needed to expand the volume so I replaced the ssd with 2 HDD to have 8 disks in RAID 6.
Can't see any performance degradation at all. SSD cache comes into use if you plan to run iSCSI and/or virtual machines in the NAS,
No benefit whatsoever for normal usage (streaming, backup and such).
In your case you have 4 drives occupied with 0 drives left for any ssd cache, meaning that you can't install any ssd cache at all.
Exactly what Doublee stated, adding cache acceleration will not make any difference with basic operations.
I was hoping for the same thing and added two Samsung SSD's for read and write acceleration which gave me no benefit at all. You are probably better off trunking your NICs to handle the bandwidth demands.
