I'm running low on space and I would like to migrate off my 2x WD20EADS to 2x WD60EFRX. The manual seems to suggest I can just "expand capacity" to expand the RAID 1, keeping all my data. Is it this simple or are there some gotchas I need to know about?
Thanks for your help,
Tim
PS Requested minimum data set below
Your Operating System you are using to access your NAS: Windows 7 SP1
NAS model 219P
Firmware Version/Build numbers 4.2 (current build)
Network Setup (ie Single Port or Port Trunking): Single Port
If Port Trunking is present please specify (choose correct one):
Balance-rr (Round-Robin)
Active Backup
Balance XOR
Broadcast
IEEE 802.3ad (Dynamic Link Aggregation)
Balance-tlb (Adaptive Transmit Load Balancing)
Balance-alb (Adaptive Load Balancing)
If Disk related please also specify:
Drive Configuration: (ie SingleDrive, RAID0, JBOD, RAID1, RAID5, RAID6, RAID10) RAID1
Number of drives 2
For each drive please provide:
Drive Manufacturer (ie Seagate, WD, Hitachi, etc) WD
Drive Model WD20EADS
Drive Firmware revision (if available) 01:00A01
TS219P Disk replacement
TS251B
Re: TS219P Disk replacement
no that should work just fine, just follow through with the "expand capacity" steps and you should be fine
just make sure you have a current backup of your files, just in case something goes wrong
- schumaku
Yes ... pray the remaining Green don't go belly up during the full RAID1 resync.
Thanks! I'll keep you posted once I have the WD60EFRX's.
Cheers,
Tim
Cheers,
Tim
TS251B
@Dolbyman and @schmaku it all went without a hiccup. Thanks for your advice.
Tim
Tim
TS251B
