Which risk in create a total different RAID with new disks?
- Easy as a breeze
I've a 4 disk RAID that i use in a profitable way on my TVS-471 system.
I'm wondering what happen if i buy another 4 WD RED disks and replace 1 by 1 the old disks with the new one (1 by 1 so in this way the new inserted disk will be rebuilt with the current RAID configuration mantaining data and settings, repeting this procedure for all the 4 disks), will i be able to switch back to the old disks (and old RAID)? I mean, for the system, the OLD raid will be exactly the same as the NEW raid so i can switch them without the risk of loosing configuration and data?
Re: Which risk in create a total different RAID with new disks?
I wonder why you want to do this, because I think you didn't get the technical idea/background of RAID, Volume and/or Storage Pools
But yes it should be possible AS long as you don't extent the volume/storage pool size after replacing the drive with (potential) larger ones. A complete reverse requires a one-by-one change of each drive of course.
Just for your understating: The Volume or storage pool that is living on the drives will not be changes if you change your drives one-by-one. Just the underling media/drives change so that the new drives become part of the old volume. ..
You should never insert disks containing data into a NAS!Benna80 wrote:I mean, for the system, the OLD raid will be exactly the same as the NEW raid so i can switch them without the risk of loosing configuration and data?
There is only one exception to the above rule and that is when doing a System Migration, moving all disks from one powered down Qnap to another (on supported models only).
- Easy as a breeze
I agree with you johnripper, i'm not that expert on RAID systems, that's why i'm trying to clarify my ideas.
For example, suppose that i would like to test some configurations but not on the "production" system. The idea was to replicate the exact same configurations by rebuilding the RAID system, and being able to swap the 4 disks whenerver i want to switch between production system and test system.
Well if you later power down and swap all 4 disks back at the same time and in the same order, that would be like a System Migration to the same model NAS so yes it's supported and should work.Benna80 wrote:The idea was to replicate the exact same configurations by rebuilding the RAID system, and being able to swap the 4 disks whenerver i want to switch between production system and test system.
- Don
You cannot replace them one at a time and then use the disks you removed to insert all at once and have a working raid because the disks would be out of sync.
- Easy as a breeze
Ok DON, help me please In understanding your sentence: what do you mean with "out of sync"?Don wrote:You cannot replace them one at a time and then use the disks you removed to insert all at once and have a working raid because the disks would be out of sync.
P3R states that in theory the system should startup again...
- storageman
- Don
You mentioned replacing the disks one by one. You replace the first disk and lets say it takes 15 hours to rebuild. You replace the second and another 15 hours. Same for disks 3 and 4. so you now have 4 disks that were removed from the raid array all at different times. None of these disks are in sync with one another so can't be used to mount a raid.
- Easy as a breeze
Ok, then, is there some other way to accomplish my objective?
shut the NAS down,
take all drives out and clone them externally 1:1
Put them back in, and you have a perfect copy off all member drives at shutdown time
- Don
Have a separate system for testing and backups and don't F around with a production system.Benna80 wrote:Ok, then, is there some other way to accomplish my objective?
I wouldnt do this. There is no garantee that this will properly work, and there is a risk that you kill your actual RAID set.dolbyman wrote:shut the NAS down,
What do you really want to do? Just let us know your scenario and we can assist.Benna80 wrote:Ok, then, is there some other way to accomplish my objective?
What are the needs, what are the restrictions? About how many data we talk? etc...
Get a second NAS
Setup NAS to NAS backup
That basically Goes along with Don's comment
Don wrote:Have a separate system for testing and backups and don't F around with a production system.
