External drive allocation question
- degsie
I have three external usb drives connected to my TS110. When I reboot or perform a firmware update, sometimes the drives get allocated different labels. For example what was USBDisk2 becomes USBDisk3 etc. As I have the drives shared on the network this becomes a problem. Is there any way to mitigate this? I'd prefer not to have to plug/unplug the drives if at all possible. Thanks.
TS110 (4TB WD RED)- QTS 4.2.6 Build 20190322[Retired]
TS251A - QTS 5.0.1
TS251A - QTS 5.0.1
- degsie
Re: External drive allocation question
So I guess nobody has an answer? Pity as I thought someone else might have come across this.
TS251A - QTS 5.0.1
TS251A - QTS 5.0.1
- Don
They have and it has been discussed many times in the form already. Try searching the forum.degsie wrote:So I guess nobody has an answer? Pity as I thought someone else might have come across this.
- degsie
Ok, wasn't sure what search keywords to use (maybe you could have suggested some?) but I did find a discussion on renaming the volume label which my TS110 does not support. So I guess I am stuck with this shortcoming.
TS251A - QTS 5.0.1
TS251A - QTS 5.0.1
