Power down works fine, Power on doesn't
I use a brandnew TS-219 P11 firmware 3.6.1, 3TByte seagate HDD's in RAID 1 mode.
I use a simple powermanagement schema:
- daily shutdown at 23:59
- daily restart at 18:00
The problem is that the unit correctly shuts down at 23:59 but never powers up again.
Any suggestions please?
Re: Power down works fine, Power on doesn't
Rather than restart, select "Turn on the server" from System Administrator > Power Management. Should do what you're looking for!
Update:
- QNAP advised to reload the firmware again to make sure that it was properly installed. After doing this I got the same result: power-down keeps working, power-up still doesn't.
- I tried "Turn on the server" as advised bij "clickright". Same result: power-down works, "turn on te server" gives no result (unit stays power-down).
Any further suggestions please?
"Turn on the server" is the only setting that should turn the server on so that's the one to use.
You don't cut the power to the unit during the time it is down do you? I guess that could prevent the startup.
To P3R: there is no power cut whene the unit is down. All my computer stuff is instralled on separate electrical groups.
Sounds like it could be a bug but I have no TS-219P II to verify. No UPS in place?
Maybe someone will get an idea if you show us a screenshot of your System Administration, Power Management page?
- pwilson
Perhaps you could simply enable the "Wake-On LAN" feature", and simply wake it up from elsewhere on your network, by getting another machine on your network to wake up your NAS at the appointed hour. (I used to do it from my Router (DD-WRT Router firmware installed), but I finally decided that the power requirements for QNAP NAS unit is so low, that I now simply leave my NAS on 24/7/365. My drives go to sleep properly, so I don't expect 24 hour operation to cause pre-mature HDD failure.Hansbird wrote:I use a brandnew TS-219 P11 firmware 3.6.1, 3TByte seagate HDD's in RAID 1 mode.
Shutting down my NAS "at night" wasn't saving me much money, and it was causing Torrent downloads to get screwed up. I now operate my own phpBB3 Forums system on my NAS as well, so now I need to leave it on 24/7 so people can access my Forums system. It only consumes 35W when in use, so I'm not really worried about it.
Good luck resolving this issue, it must be very frustrating.
Patrick M. Wilson
Victoria, BC Canada
to P3R: I don't use an UPS.
My settings are:
EuP Mode Config: Disable
Configure Wake on LAN: Enable
When the AC power resumes: Resume the server to the previous power-on or power-off status
And then follows the Schedule I provided earlier.
To Patrick: I think in pratice you're right; it won't save a year earlier retirement . The only thing is, I want to have the unit work properly.
My settings are:
- sl1000
enable eup mode, powercycle the nas (really unplug for 10 secs from the wall outlet), let it boot, disable eup mode again, powercycle again. after that it should be working imho.
Update:
- I was advised to try the new 3.7.0 firmware. This resulted in a complete invisibility off the NAS. Even the NMAP tool wasn't able to "see" the NAS any longer. I learned later on that the firmware for my model QNAP was not functioning properly. I completely reconfigured the NAS from scratch (Yes I had a 100% backup available).
- 3.7.1. came along. I upgraded the NAS to the newest level. Result: the same. The Unit powers down perfectly but never comes a live again.
- I'm now wainting for the final answer from QNAP support before I'm returning the NAS to the store and buy me a another NAS.
Update: I'm using 2 x Seagate ST3000DM001 3 TByte HDD. The Disk is on the HCL.
update:
@S|1000: I tried your suggestion. I didn't work out, Thx for your time.
- sl1000
Then def. contact qnap support. Sorry it didn't work out
Last Update:
QNAP support advises to bring THE unit to THE dealer for repair. We"ll see wat happens.
- schumaku
You should ask for a replacement - well posible this is a hardware issue ... as there is dedicated hardware in place to control the scheduled power-up. As this has not worked from the begining, the device was broken from day one - so in most legislations, this gives you the right for a direct replacement.
