I have a RAID 5 array of 10 drives on my TS-1079 Pro.
I would like to move all 10 drives to a new TS-1270U-RP.
It's my understanding that as long as the motherboard of the new NAS (in this case, the TS-1270U-RP) uses the same chipset as the original NAS, then the data will remain intact in the new RAID 5.
Is this true? Can I simply move the drives from the TS-1079 Pro to the TS-1270U-RP (in order, of course) and retain the data? Or is it not that simple?
Moving Drives from TS-1079 Pro to TS-1270U-RP
- pwilson
Re: Moving Drives from TS-1079 Pro to TS-1270U-RP
Moving the 10 Drives over is that easy. Check out the Migrating from Old NAS section of the fine manual.rsmedia wrote:I have a RAID 5 array of 10 drives on my TS-1079 Pro.
Patrick M. Wilson
Victoria, BC Canada
Note that with 10-12 drives the chance of failing 1 or 2 drives at the same time is 10-12 times higher than with single disk. That can be less than one year. I would recommend you using RAID6 or 2xRAID5 (and maybe 3xRAID5) with new storage pools feature.
experience with administration of UN*X (mostly linux) and applications on internet servers since 1994...
