2. Firmware revision: current
3. Network Setup: single 100 MBps cable to Wi-Fi router
3. Two 2TB HDDs in RAID1
Yesterday I updated to the latest f/w.
I also copied about 10GB of new files to it (mostly PDF, ZIP, some vids)
I tried to transcode just one movie from RealMedia and system load jumped to 20-30. I later disabled transcode in the GUI and also deleted the job.
But even before that things didn't look good as I noticed that system load was between 10 and 15.
After I disabled transcode system remained busy (system load of 10-15).
I think it all started before the transcode thing, as soon as I attempted to use Media Station (similar to http://forum.qnap.com/viewtopic.php?f=2 ... 5&p=349034).
As I started feeling strange I was looking at top output while I was trying to access Media and Video station: I think ffpga got stuck trying to generate thumbnails from the many videos I had in one folder (they were there before, but I never used Video Station, so I guess those hadn't been generated until today).
Anyway, after I disabled transcode and system load remained high (10-15) and I could see ffmpeg processes (but each consuming just few % of CPU; I didn't understand how could those make so much I/O). Then I rebooted the box but it didn't get better. I was using Twonky DLNA and I couldn't even play MP3s over LAN.
In the past hour or two I've been pinging the NAS with "-t" and only one packet missed to arrive. But at the same time I can't load the Web GUI (proxy timeout!) and neither can I login via SSH (Putty just hangs in there, no error/timeout, but also no response of any kind).
Here's what I get when I access http://NAS:8080:
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /.
Reason: Error reading from remote server
Apache Server at NAS Port 8080
EDIT: I changed "CPU busy" to just "busy" as it may be either I/O (and the CPU may be waiting) or CPU, I'm not sure which one it is.
