Last week I followed an article in the support forum, about a process which caused a high CPU load.
I followed the instructions an Reboot was required.
After the reboot I got an error, stating I needed to scan my The file system is not clean. It is suggested that you run "check disk""
So I did.
And a timer started running but after a few minutes, a notification came, claming it was unable to mount.
I turned off all apps in App-Center
And followed the following steps listed in http://forum.qnap.com/viewtopic.php?f=25&t=83199
The steps I followed.
[/] # /etc/init.d/services.sh stop
[/] # /etc/init.d/opentftp.sh stop
[/] # /etc/init.d/Qthttpd.sh stop
[/] # /etc/init.d/smb.sh stop
[/] # /etc/init.d/timemachine.sh stop
[/] # /etc/init.d/bonjour.sh stop
[/] # umount /dev/md0
umount: /share/MD0_DATA: device is busy
[/] # lsof /share/MD0_DATA
#I killed the last process manually.
unmount: Succesful
So I tried a manuel scan.
e2fsck -f -v -C 0 /dev/md0
Error allocating block bitmap (4): Memory allocation failed
I would like to have my data secure, but it's not really comforting, that it says something is faulty.
Hope someone can help me.
Thanks in advanced.
